problem with 1972 truck
I am having a problem with my 1972 truck here is whats happening I change the fuel pump and it started up and ran for awhile than it quit. I checked for spark and I didn't have any spark from the coil as it turns over but won't start can anyone help me with this problem so I can get my truck to run.
Do I need to get a new coil
not sure how to find out if this post is getting out to people but will try this again. Have a 1972 Ford F100 360 installed a new fuel pump started truck up it ran than I turn it off tried starting it next day and it would not start but turn over very good I than checked for spark found no spark from coil held coil wire against bolt on engine did not see any spark from coil so do I need a new coil would appreciate help on getting truck going thanks
on
Hi David, welcome to FTE!
This forum is for new member introductions. You need to post your questions in one of our tech fourms.
Try here,,, FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) - Ford Truck Enthusiasts Forums
Or maybe here,,,, 1967 - 1972 F-100 & Larger F-Series Trucks - Ford Truck Enthusiasts Forums
Be sure to stop by and say Hi to the local chapter FTE has for Montana members. You will find the chapter here,,,, 1967 - 1972 F-100 & Larger F-Series Trucks - Ford Truck Enthusiasts Forums
earnhardtracer38
07-30-2022 04:38 PM
