egr valve - Ford Truck Enthusiasts Forums
egr valve
Old 05-05-2013, 06:01 PM
stallion3599 stallion3599 is offline
stallion3599 is starting off with a positive reputation.
egr valve
I have a 66 f 100 with a 77 300 in it. I had the carb rebuilt, the manifold has an egr plate on it. I put a hose on it and had it hanging. apparently a Dirt Dobber built a nest in the hose, clogging it and apparently it blew my carb out as now gas pours out everywhere. I had the carb rebuilt last year and have no miles on it, do I need to have it rebuilt again or can I replace a couple gaskets in it myself? it cost 80 bucks for the last rebuild.
Thanks
SP
Old 05-05-2013, 10:42 PM
kjvforme's Avatar
kjvforme kjvforme is offline
kjvforme is a name known to allkjvforme is a name known to allkjvforme is a name known to allkjvforme is a name known to allkjvforme is a name known to allkjvforme is a name known to all
sounds like the float/needle is stuck and not shutting off fuel. the fuel overflows and comes out the bowl vent. Tap the bowl area with a scewdriver handle and see if it frees it.
Carb Adjustment JCastellaw 1966 - 1977 Early Broncos 18 04-03-2011 11:43 PM
Help w/rebuilt carb on 292 -y-block 1964_mezajd 1961 - 1966 F-100 & Larger F-Series Trucks 8 04-13-2007 03:22 PM
1-bbl carb question 91f250460 Ford Inline Six, 200, 250, 4.9L / 300 3 05-31-2005 01:03 AM
EGR spacer exhaust leak? BigBrownTruck 1973 - 1979 F-100 & Larger F-Series Trucks 2 07-29-2001 12:47 PM
1987 Bronco 5.8L Holley 4 barrel petuniapus 1978 - 1996 Big Bronco 4 03-28-2001 07:04 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
