Can't say for sure because I can't see where everything is hooked up, but it's in the right spot for what looks like a home brew overboost code fooler.
I had a buddy that put an air compressor pump where the A/C compressor went on a 98 Blazer. He built a bumper that was an air tank. It was pretty slick!
I would have to say it is a Diesel flux capacitor! Boost hits 88 PSI and you jump to the future!
Because the bracket doesn't fit the Excursion due to the rear AC lines. It has to be modified to work.
Stewart
Thanks!
I am beginning to think nothing fits an excursion. It seems as if, its for a F250/350 it probably CAN be made to fit the excursion. It brings out the tinkerer in us!
EXv10, I tried to get both ends of the host. In the second photo, you can see the clamp at the far end of the red hose where it connects to something up on top of the engine. In the first photo, the left side of the red hose, where it 'disappears' in the photo, is where the hose actually ends and connects to the black plastic thing. I assume the black thing is a pressure sensor of some sort.
I bet you guys are right. It's probably just there to regulate the boost to the sensor.
