SD HPOP on 95 7.3L - does timing cover need mod?
New to the forum, but it's already provided a wealth of information. I am in the middle of quite a few mods on a 95 Superduty. Doing an e-fuel conversion, 99.5 + turbo and intercooler with E99 spider. New up pipes with bellows, and regulated fuel return. Fuel bowl delete with mechanical pump delete.
Question to the experts, I want to upgrade to stage 1 or 2 injectors, so I'm wanting to upgrade the HPOP. Thinking of a SD 17*. I've read that my timing cover may need modification. If so, what needs done?
Thanks in advance!
Thanks in advance!
You have to have the pump modified to work on the 94-95 trucks. If you send it to Joey at terminatorengineering, he can modify it to bigger than a stock 17* SD pump, it will be called a T500. Price isn't bad at all either. You can look it up on riffraff's website. Riffraff Diesel Performance Parts | Ford 7.3 diesel | 7.3 powerstroke | Ford Powerstroke | 7.3L Powerstroke Parts
Welcome to fte by the way!
Kinda pointless to mod the front cover in my opinion. If you go with stage 2 injectors, you should have something bigger than a stock 17 to supply them anyway. I guess if you stay with stage ones you could save some money by using a stock 17 and mod the cover, just don't screw up like Mike said.
Here is the write up for the front cover modification. I saved this to my computer years ago before I knew it was possible to just modify the HPOP instead of the front cover.
http://www.nigh.org/HPOP_Mod/HPOP_reservoir_HowTo.htm
There's the info for you. Now it's up to you to decide if it's easier to just get a T500 or mod your cover and run a stock 17* pump that flows less oil. IMO, just get the T500.
a ayala
09-04-2011 05:19 AM
CARP82
02-15-2011 03:37 PM
dazed12769
07-15-2002 12:16 PM
