Power window out AGAIN - Ford Truck Enthusiasts Forums
2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Old 05-04-2013, 08:33 PM
Kelly Aitken Kelly Aitken is offline
Kelly Aitken is starting off with a positive reputation.
I have a '08 Navigator. Had the driver side power window motor replaced a couple of years ago while it was still under warrenty. I was told then by a service tech that this is a very common problem. I have been out tof the country for about a year and a half now and my wife and son only drive it occationally. It is now out of warrenty and the window is messing up again. It goes up alittle bit and you have to keep hitting the switch untill it finally goes all the way up. I bet it doesn't have 10,000 miles on the truck since it was replaced last time. This is going to cost me this time. Anybody else have this issue? Is there a better fix? Thanks
Kelly
Old 05-06-2013, 03:37 PM
jimb726 jimb726 is offline
jimb726 is starting off with a positive reputation.
Quote:
Kelly
Just for giggles, before you take it in, try spaying some silicone spay on the window tracks on each side of the window. Spray it liberally and then work the window up and down a few times. Sometimes the track gets crud in it. This may help. Lot cheaper than new regulator or motor.
Rear gate won't unlock Kelly Aitken 2007 - 2014 Expedition & Navigator 0 03-11-2014 11:29 AM
Interior Ground - Windows/seats issue '87 me_iam 1987 - 1996 F150 & Larger F-Series Trucks 0 08-15-2011 10:43 PM
What carb would you use Kelly Aitken 1967 - 1972 F-100 & Larger F-Series Trucks 0 09-20-2010 08:13 PM
Couple Arrested For Asking For Directions jake00 General NON-Automotive Conversation 31 05-25-2006 09:47 PM
Power windows mistakenID Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 3 11-07-2005 09:19 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
