Can someone tell me what this part from my C6 is?
It looks like part of the main control valve.
Open the link below and scroll to the bottom of the page, it's in roughly the center of the illustration.
There is no part number, just a % sign, because this part wasn't available separately. You could only get it as part of the control valve.
That looks like the right shape but the illustration shows it having a counter sunk hole -- mine does not have that. 371698-S also looks shorter than the bolt that I have.
Of course, the illustration could be wrong.
Is there any way to figure out how long 371698-S should be?
Did someone forget loc-tite when they rebuilt this?
I've never worked on a transmission before -- can I put this back in without having to pull the tranny?
Could be 'gypo' replacements from a trans shop like Aamco.
Is there any way to figure out how long 371698-S should be.
If you think Mike's (1973/79 Ford Light Truck Parts Catalog) illustration is wrong, here's 4 more to gaze at. Same two parts shown in all of them.
Pulled the main control valve (easy) and put this part back in. What purpose it serves, I have NO idea. It doesn't touch or rest on any other piece. It doesn't help index the main control valve to put it back in. It doesn't seem to do ANYTHING but I trust that Ford engineers put it there for a reason so I felt better about putting it back.
Whole process was pretty simple. Was a little tricky getting the control valve to interact with the shift linkage correctly but (I think) I figured it out. Seems to shift fine.
Just need to replace the pan gasket and fill her up before I can try it out.
SteveBricks
S. California Chapter
29
09-30-2008 08:14 PM
