S. California Chapter Join Chapter, Leader:
Oops rim size
Old 06-18-2013, 08:59 PM
wpnaes's Avatar
wpnaes
wpnaes is offline
Found an 'outie' on CL. Classic aged rubber to boot. Should be a slight step up from my splitie that no one will risk changing.
Do they still make valve stems like that?
Added a coat of silver. Bottom pic is the van rim, catywampus pic.
Old 07-14-2013, 03:39 PM
wpnaes's Avatar
wpnaes
wpnaes is offline
Finally got around to removing the other wheel (tire has a nail in it). I broke off one lug stud.
If you look at pic 2 (post 2)' there are 3 slot screws. Do they hold the drum on? There is likely a ridge on the inside, so I'll adjust the star nut inside. One wheel has some interference inside; easy to turn 40 degrees, the other 140 degrees are difficult to turn. The opposite wheel spins freely.
Old 07-14-2013, 04:41 PM
SteveBricks's Avatar
SteveBricks
SteveBricks is offline
The three screws retain the drum
Old 07-14-2013, 11:52 PM
OldBlackCat's Avatar
OldBlackCat
OldBlackCat is offline
Get the drum off today Sean?
Old 07-15-2013, 06:47 AM
wpnaes's Avatar
wpnaes
wpnaes is offline
Nah, I got sidetracked. That sloppy red paint was bugin' me.
Old 07-15-2013, 06:22 PM
OldBlackCat
haha! nice
Old 12-15-2016, 04:28 PM
wpnaes's Avatar
wpnaes
wpnaes is offline
3 years later
Decided to open up the drum and see what's what. I had a used set of blocks lying around, so will put those in. Also need to seal up the pumpkin cover - plenty of leakiness.
Was considering surge brakes - I know hydraulic isn't the best on these, but would it be better than 'nuthin? My stop time all loaded for camping isn't great with just the Excursion brakes.
https://www.etrailer.com/Brake-Actua.../T4715420.html
Old 12-15-2016, 10:30 PM
SpringerPop's Avatar
SpringerPop
SpringerPop is offline
Finally found that round Tuit?
Pop
Old 12-15-2016, 11:08 PM
OldBlackCat
nothin wrong with surge brakes!
Old 12-15-2016, 11:47 PM
SpringerPop
.... Unless you back up-hill a lot. Then, they're a PITA, even with lock-outs.
Pop
Old 12-16-2016, 08:05 AM
OldBlackCat
Pop
luckly seans a step ahead of us and listed one that comes with the reverse lockout solenoid.
Old 12-16-2016, 09:01 AM
wpnaes's Avatar
wpnaes
wpnaes is offline
Pop
That was my worry also Marv. My trailer parking spot a home is an uphill approach, so we'll see. I haven't yet ordered the part; they have manual latch activated lock-outs too, but the solenoid connected to the reverse circuit seems handy.
  #28
Old 12-16-2016, 10:18 AM
OldBlackCat
if the manual latch is built into the coupler like the one i delt with the moment you pull forward it unlatches. The solenoid should be the better way.
little more costly but you could always just put a standard trailer axle with electric brakes under it and get a controler.
  #29
Old 12-16-2016, 02:35 PM
bpounds's Avatar
bpounds
bpounds is offline
Youse guys must be a lot better at backing a trailer than I am, if you can do it without for/rev about 15 times
Surge brakes suck, but if you must use them, by all means go with the auto-lockout.
  #30
Old 12-16-2016, 04:05 PM
wpnaes's Avatar
wpnaes
wpnaes is offline
I haven't found an 'off the shelf' i.e, inexpensive 6' wheel flange to flange that fits my 8 lug, 6.5'' circle wheels. Granted I've not looked very hard, but no doubt one could be made.
To your point, I can run a lotta fuel through the V10 (paying in mpg) for the increased resistance of the pumpkin and axle weight vs. the cost of a new 'lectric axle.
Indeed, Justin and I are awesome.
We could totally do this maneuver...
Quick Reply: Oops rim size
