loose shock
Old 05-04-2013, 12:02 PM
robtrev64's Avatar
robtrev64
robtrev64 is offline
loose shock
Well, I had a friend put together my front brake rotor, now no more pulsating when coming to a stop, very smooth stop, new front brakes, had it aligned as well.. Also replaced the front shocks, however the passenger side came loose and rattles when going over bumps, speed bumps. I popped the hood, bounced my truck and could see it moving from left to right when bouncing front end of truck.
Question is, can i tighten it up myself, I dont have a jack, limited tools, I know, I know but i dont at the moment. My friend that worked on my truck lives a good drive and i hate to waste gas just for tightening something that should have been done but i have too, I will.. help..
Old 05-05-2013, 07:51 PM
ranger pat's Avatar
ranger pat
ranger pat is online now
Just tighten it up until the wrench is too hard to turn. Keep an eye on it for a week or so and you should be good to go.
Old 05-06-2013, 11:44 AM
reddog99's Avatar
reddog99
reddog99 is offline
The upper nuts should be torqued to 30-40 ft/lbs. If you don't have a torque wrench, then tighten the nut until there is some noticeable bulging of the rubber bushing, but don't over-do it. It shouldn't bulge much past the diameter of the large diameter washers.
Old 05-07-2013, 11:43 PM
KungFuGrip's Avatar
KungFuGrip
KungFuGrip is offline
Shadey Tree torque wrench! It works!
xamack24
02-05-2013 10:51 AM
publiuss
08-01-2012 03:31 PM
wildcat99
10-14-2007 09:02 PM
Biggziff
1999 to 2016 Super Duty
06-14-2007 08:50 AM
Quick Reply: loose shock
