CROWN VIC EXPERTS NEEDED
Alright gang.... I have a line on a 2011 crown vic. for the right money.
questions are....
will the suspension out of a 2011 work? is it the same as the 2003 version I keep seeing people use?
Will this 4.6 accept the edelbrock carbureted intake and electronic ignition kit?
questions are....
I agree on the engine issue. Yank the whole assembly and go with the EFI. There a couple of guys on this site that can modify the wiring harness on the donor car to work in your truck. As for the suspension of the never CV, I'm not savee on that, but I think they may be the same as the older ones. Good luck.
no matter who manufactures the carb'd intake for the 4.6 , they are a single plane intake meant for racing . won't run worth a crap on the street unless your gonna build an animal and gear it to hades and a high stall converter ...... if you want to run it best to take the harness and all and leave it fuel injected .
Thanks guys.....
The main reason why i ask about the suspension is that after searching car-parts.com for interchangeability, i found the "engine cradle - aluminum" to be specific 2003-2007 and a differnt item from 2007+. Which made me think the suspension for donor purposes might be different than what everyone else is using.
So if everyone here tells me they are the same i will make the offer on the car.
i'm not for sure but i believe the newer vic's track width is to wide for our trucks . so you might wanna check into that before you buy it . i know for sure as i had one i parted out , and mechmchn aka jeff on here used the front suspension from a lincoln variant on his truck , but the square body vics of the early 80's and mid to late 80's will fit .
1964 MP&L F100
04-03-2014 05:40 AM
Old Rusty
02-21-2014 12:23 AM
jasmyers1
07-13-2012 06:32 AM
Truxx1956
05-19-2011 08:09 PM
bluespark11
12-22-2003 06:29 AM
