Lunch box truck build thread with pics!
#62
#64
Thanks for the complement Andre!
Thanks Bently, I'll have more updates soon(er)
I need your help installing the Mini-Maxx, I can't find the OBDII connector on this dang thing. It's all good with the wife since it's out of warranty.
Thanks Marc, I just saw the pic of your FE, it looks great. I was going to pull out my FE and replace it with a I6 or 6BT, but you and HIO have me thinking about keeping the FE.
Yes I am, and thank you very much.
#65
But beyond that, you can stroke the **** out of them without a lot of block work and get boat loads of torque.
The after market is red hot right now for them as folks are waking up to the potential.
As far as the mileage thing, my theory is that if you build lots a torque you don't have to push on the go pedal so much (except for fun) so you save many drops of go juice. And you can put an overdrive unit inline and have the torque to turn it at low vacuum levels saving more fuel. I'll let you know how that theory works out.
Nice work on your build.
#67
#68
#70
Yes I did, thanks again for the Blackbirds pro tip! Randy at Blackbirds got me everything I needed. There was some machining required on my part but it was no big deal. I just got the front axle off and I need to do some shock mount work on it, paint it, put it together and I will post the whole process in it's own thread.
Sorry for the delayed reply.
Gavin
#71
New Skyjacker rear leaf springs to replace the PO2s springs.
It was a PITA getting the old springs out, the bushings wallered out around the mounting holes on the rear hangers. I had drill them out so I could weld in some bushings.
I had to pry apart the hanger.
Milled out the old bushings.
I turned the bushings for the rear hangers and turned thin bushings so the rubber bushings were tight.
Painted up and ready to install.
Setup for centering the bushings in the hanger.
I'll have to finish welding the top of the flange when I take the bed off.
Wow, the new leaf springs are really bowed. At first I was going WTH??
Finally, I got the rear axle back under the truck....
....and I got the new seat covers on.
Next up, removing the front clip.
#72
#73
Received 5,157 Likes
on
#74
Thanks Gerry, I appreciate that!
