2007 f150 4x4 xlt 5.4 triton - Ford Truck Enthusiasts Forums
Old 05-03-2013, 04:36 PM
Jeremy Derby Jeremy Derby is offline
Jeremy Derby is starting off with a positive reputation.
I have a problem and i was wondering if someone could point me in the right direction. My 2007 ford f150 4x4 5.4 triton engine starts to flutter and stalls when its in reverse, engine is warm, and im backing up a trailer with about 5,000 lbs on it. It drives fine with or without towing. I did notice it does it with nothing behind it on occasion. Anybody know whats causing this?
Old 05-03-2013, 10:08 PM
charz charz is offline
charz is starting off with a positive reputation.
Quote:
any Codes?
sounds like either chain tensioners or cam phasers, is there a knocking sound or a rattle when you reverse?
Old 05-04-2013, 11:18 AM
TexasReb TexasReb is offline
TexasReb is starting off with a positive reputation.
I had that same issue back in 2007 with my 05 5.4L and had Jennings Anderson Ford repair it under warranty. They ended up replacing a valve in my transmission and all has been good since.
2007 5.4 Triton Camwalk onewirenut New Member Introductions 2 08-26-2014 09:08 AM
engine swap 3v 5.4L triton with a 2v 5.4L triton Xx0573 Modular V8 (4.6L, 5.4L) 4 07-04-2013 12:32 AM
sherrod 5.4 triton V8 Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 1 07-09-2012 02:14 PM
2007 Ford F-150 gear ratio question 07F150Lariat5.4 2004 - 2008 F150 7 01-30-2011 02:15 AM
5.4 engine good or bad triton20x 1997 - 2003 F150 3 02-25-2008 07:25 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
