'37 Pickup project
#31
#32
It happened on the front drivers side disc brake so I'm taking it to my friend's shop since I don't have the tools to get the caliper off. I did get to drive the truck around the yard and the rear brakes worked to stop it since it wasn't going fast. I don't yet have the trans lockup wired so it had to work hard to get moving. Also for some reason the power steering doesn't work. I got some smoke off the exhaust manifolds, hopefully just burning off some coolant or something, and nothing worse.
#33
Got new tires put on today. The 235/75/r15 were too big and rubbed the front fenders. This is due to the fact that the front tires stick out further on a 4x4 s10. The new tires are 215/60/r15. They seem a little small at the moment but it should look better once I lower the front and back 2".
#34
#37
Have to modify the dipstick tube because its slightly larger in diameter than the stock one. Got my Heddman longtube headers today, will send them to get ceramic coated soon as possible. Exhaust will be duals with h crosspipe and exit before the rear wheels. Still not completely certain about the exit location though.
#38
Not alot to update yet. Got my headers coated and installed. Unfortunately I need to get a set of taps because one of the manifold bolts wont go all the way. Im guessing just some gunked up threads. Also made new plug wires so they are a little nicer looking and clear the headers. Plans are to move the fuse box to a new location and install a bulkhead connector to clean things up a bit.
#41
1937
Hi, Nice 37... Looks like you are making progress on your own I also am restoring my 58 on my own SLOWLY for a year now and you do learn allot, as far as the header paint it will last awhile because I painted mine on 58 Ford F250 292 Y Block about 9 months ago and it still looks great and it has not burned off, so you should be fine. Sorry to hear your Father Passed away mine did too approx 1 1/2 years now and surely missed. Keep up the good work it will turn out Great....
#45
Thanks guys. It's cherry wood and aluminum strips. Plan on welding a few braces under the bed and using carriage bolts through the aluminum. This is a show truck so it wont be hauling much more than a cooler. I also plan on making a hard bed cover so Im not too worried about damaging the bed.
