Wanted: 6.9/7.3 idi parts - Ford Truck Enthusiasts Forums
WTB - Parts & other Want to buy parts/accessories/tools.
Old 05-03-2013, 02:28 PM
southtexasidi's Avatar
southtexasidi southtexasidi is offline
southtexasidi is starting off with a positive reputation.
First off, I'm looking for the alternator wiring harness for an 83-86 ford diesel. The alternator wiring harness has the needed wiring for a tach, the reason I need it.
I am also looking for the serpentine belt pulleys off of a 7.3 idi diesel. I think they started serpentine setups in 92.
If you have any of these parts or any other idi parts PM me. Thanks
Old 05-20-2013, 08:59 PM
81Bronk36 81Bronk36 is offline
81Bronk36 is starting off with a positive reputation.
Nope, nope it doesnt, the tach just goes from the tach sensor on top of the IP housing to the 2 wires in the dash that are not included on a non tach dash. How do I know? I did the swap, and I swapped a 3g alternator in so I cut the wiring harness off except the green wire. I was surprised there wasn't more to it but I fired it up the first time and its been working ever since.
Old 08-12-2013, 08:46 PM
good info thanks, i actually bought an aftermarket tach the other day...hopefully i can wire it up easily
Old 08-20-2013, 10:14 PM
dirtmister16's Avatar
dirtmister16 dirtmister16 is offline
dirtmister16 is starting off with a positive reputation.
would you be interested in a whole engine?
im going to be picking up a 88 f250 with a 7.3 and 5 speed trans.
2wd truck. i havn't heard it run yet but will be going over it before bringing it home, the guy says it will start right up without issue.
he parked it due to the the clutch pedal bracket breaking on him.
'93 7.3 IDI has noisy serpentine belt nbtone Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 15 05-11-2016 09:36 AM
Alterantor Wire Boot ( source ? ) petepetersen Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 3 12-01-2015 08:30 AM
3G alternator pulley swap question FordTruckfan89 1987 - 1996 F150 & Larger F-Series Trucks 2 04-08-2015 08:12 AM
7.3 idi swap wiring questions obsguy Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 9 02-09-2014 11:07 PM
Vacuum pump delete 4x4falcon Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 11 10-04-2013 08:51 PM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
