97 f350 diesel transmission problems - Ford Truck Enthusiasts Forums
Old 05-03-2013, 12:36 PM
jad4 jad4 is offline
jad4 is starting off with a positive reputation.
I took my truck in to a local transmission shop to have the tranny checked cause it is not working properly and they told me it is fine. I want to troubleshoot it with you guys cause im worried something is going to fail and leave me stranded somewhere.
When I start my truck it makes a air sucking noise breifly.
When it is cold it will act like it is having to work real hard and I have to really push down the pedal to get is to get going. It only does this when it has been sitting overnight and just the first 1/4 mile of driving. If I let it idle for a while it doesn't seem to make a difference, still does it.
It also doesnt want to shift in to the highest gear first thing in the morning when it is cold. It shifts into overdrive but not 3rd?. I don't even know if thats possible. Also recently I have noticed that the gear selector is very sloppy and when I shift in to drive it is sometimes actually in neutral and I have to shift a little further more towards 2nd to get drive.
I did have a tranny hose that was leaking and I ran the truck breifly with low fluid unknowingly. When the truck has been driven for a short distance everything works fine. Which may be why the tranny shop couldn't find anything.
Thanks in advance,
jeff
E4OD Now Whining Loudly; Previously Returning to Neutral Eratically The Harvester 1987 - 1996 F150 & Larger F-Series Trucks 3 02-01-2014 06:00 PM
Still stuck on tranny problems...need help fast DieselBeast01 1999 - 2003 7.3L Power Stroke Diesel 18 10-27-2009 07:02 PM
hesiation/stumble at part throrttle DrFord Ford Inline Six, 200, 250, 4.9L / 300 12 03-28-2008 01:15 PM
Shifting Issues-M5OD-R1 77300i6 Clutch, Transmission, Differential, Axle & Transfer Case 5 10-05-2007 07:34 AM
c6 stuck in 1st gear.... ford4life69 1973 - 1979 F-100 & Larger F-Series Trucks 5 12-01-2002 07:17 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
