I have a razor blade scraper I'm going to use to loosen the corners then try to pull it off , was wondering on what chemical to use to get the adhesive off or will soap and water work ...
When I took the tint off of my windows, I used a heat gun, razor blades, and a lot of time. I also used some window cleaner from a company called Spray Way, I believe, to get whatever adhesive was left.
I pealed mine then used goo gone. you can get it most grocery stores or hardware stores. Let it sit on window to sink in and then just remove. I used the bottle the spray dies not seem as strong
I just used a sticker remover (it uses the old-style razors) and some soapy water. I would use a steamer or heat gun if the tinted paper has been on the windows for a very long time. I just replaced the 4yo tinted paper and it came out mostly entire, which is what you want to happen.
This. Then use window cleaner, soap and water, whatever spray cleaner you have handy to spray down the glue that's left. Let it soak a little, they use your razor scraper to get the glue off. Keep the window wet while you're scraping.
