lowering my truck
lowering my truck
i have a 99 f250 l/d 2wd and im looking to lower it, see i have a good friend that has a machine shop, and i was wondering if i can just modify the front leaf hanger so it drops the rear 4 inch's, would it still line up properly and would it hurt my rear end or drive shaft
The aftermarket sells hangers that will lower it two inches. You can get the extra two by purchasing a used set of springs from an Harley Davidson...or the aftermarket, if you budget allows. I don't think 4 inches is enough to cause drive shaft angle problems. You might have to purchase a shorter pair of shocks.
do you know how many inches
do you know how many inches i can lower the front of my f250 l/d 2wd with factory spindles and a arms, and sway bar linkages ? thanks
I have the opposite problem. My 1997 F150 Supercab 2wd shortbed is lowered 2" in the front by using shorter coil springs and 4" in the rear by using shorter spring hangers. See my post. I did have to use shims to align the driveshaft. You probably would have to do the same or you would get vibration problems. According to DJM as mentioned in one of the posts, the shorter front coil springs are the same for my truck and yours.
Would you interested in swapping your stock parts (front coil springs and front leaf spring hangers) for my lowered parts even steven? We could pay the freight charge to ship the parts to the other person. I don't know where you are but I am in Macon, GA.
i would be interested but my truck is our only transportation so i couldnt send the parts untill i get urs and will ur front coils be the same as mine, mine coils are twice as thick as the f150 coils im in cape breton, ns, canada
I have a 99 f150 2wd and I purchased heavy duty f250ld coil springs to replace my 310K stock coils. Holding them side by side they are the same size. Different compression rate. They are interchangeable between the f150 and f250.
ya ill do it but like i said this is our only rig so i cant strip it till i have somthing to put in it
ya ill do it but like i said this is our only rig so i cant strip it till i have something to put in it
BRay09
10-03-2015 04:45 PM
fordpower46
06-07-2012 11:43 PM
