A couple of quick questions - Ford Truck Enthusiasts Forums
Old 05-02-2013, 09:02 PM
AlanMac's Avatar
AlanMac AlanMac is offline
AlanMac is starting off with a positive reputation.
1986 F250, 460 cu.in., 2WD
Just a couple of questions about the old truck...
Is the dome light supposed to come on when the door opens? It works when you reach up and turn it on manually.
http://i437.photobucket.com/albums/qq93/mcclintick_2008/Dome%20Light/domelight.jpg
The metal tubing connected to the power steering pump swings forward and backward. The nut is tight. Is there some practical reason for this or is it supposed to be stationary when tight?
http://i437.photobucket.com/albums/qq93/mcclintick_2008/PS%20pump/PSpumpconnectionup.jpg
http://i437.photobucket.com/albums/qq93/mcclintick_2008/PS%20pump/PSpumpconnectiondown.jpg
Old 05-02-2013, 10:10 PM
JayzDaddy's Avatar
JayzDaddy JayzDaddy is offline
JayzDaddy is gaining momentum as a positive member of FTE.JayzDaddy is gaining momentum as a positive member of FTE.
To answer #1 yes the middle light is supposed to come on when the door opens. If it does not
1 no power x wrong you can cut the map lights on you say
2 center "dome" bulb is blown~ possible, replace if bad
3 door switch is stuck or bad~ possible, manually work your switch, spray around push button with dielectic spray
Old 05-02-2013, 10:14 PM
JayzDaddy's Avatar
To answer #2
I dont know for sure but mine do not move easily. I dare not put more pressure on mine as i am a hulking clutz and am afraid of bending, kinking, or breaking something. In dealing with a compression type fitthing over the years it should not move without a good bit of force. Doesnt seem quite right.
Old 05-02-2013, 10:17 PM
ctubutis's Avatar
ctubutis ctubutis is offline
ctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputation
It doesn't surprise me that they move, they have O rings and are designed to be able to move to accommodate engine movement and to transmit less vibration.
06 SRX Caddy Seats for a 73-79 (or othwr yrs) oft Ford Truck Parts for Sale 0 11-10-2014 10:36 PM
Ranger Bed 6' 1993-2012 PlumCrazy* Ford Truck Parts for Sale 2 09-25-2014 05:38 AM
Fuel leak from carb AlanMac 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 38 05-15-2013 08:36 AM
pic test AlanMac User Gallery & Picture Display 6 05-13-2013 11:13 PM
Darn fuel pump! Please help. AlanMac 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 8 05-01-2013 01:19 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
