2003 explorer key stuck in ignition - Ford Truck Enthusiasts Forums
Old 05-02-2013, 09:45 PM
joestanf joestanf is offline
joestanf is starting off with a positive reputation.
2003 Ford explorer 4.0 L automatic, Can not remove key from ignition, key does not appear to be turning back completely to position 1. The buzzer continues going off even if all doors closed
Old 05-02-2013, 10:28 PM
Ridenred333 Ridenred333 is offline
Ridenred333 is starting off with a positive reputation.
The key may be bent this happened to me. Try squirting a little wd in there and see if you can wiggle it out. You may have to call a lock smith.
Old 05-03-2013, 12:54 AM
shorod's Avatar
shorod shorod is offline
shorod has a very good reputation on FTE.shorod has a very good reputation on FTE.shorod has a very good reputation on FTE.shorod has a very good reputation on FTE.
Also make sure the truck is fully engaged in Park. You might want to try shifting to neutral and back to Park. Also, you might need to slightly turn the steering wheel to unload the key lock so you can turn the key all the way back.
-Rod
Old 05-09-2013, 11:24 AM
Quote:
-Rod
I think he go it because he never cameback.
97 explorer question slaterkey General Automotive Discussion 3 01-24-2014 08:41 AM
2003 Excursion ignition punched out? ruffneck30 Excursion - King of SUVs 10 01-08-2014 10:49 AM
Truck won't start, key stuck in ignition, unable to open hood Trail horse trucker 1999 to 2016 Super Duty 21 05-16-2010 06:21 PM
Does a 99 Explorer have a key chip? FordTrucksKickGM Explorer, Sport Trac, Mountaineer & Aviator 2 12-15-2008 04:45 PM
key in ignition warning chime broken wire 1997 - 2003 F150 7 09-30-2003 07:33 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
