Front Fender Mounts - Ford Truck Enthusiasts Forums
Front Fender Mounts
Old 05-02-2013, 02:18 PM
D57 D57 is offline
D57 is starting off with a positive reputation.
Front Fender Mounts
Can somebody shoot me a picture or describe the way the front end group mounts on to the stock frame? I'm putting my old cab('57) on an S-10 frame and I don't have the old stock mounts or frame to reference. I could just make something up but my front end group is pretty much rusted out and I'm planning on replacing it eventually with a sound one I've located. I want to be able to make the transfer using the stock hardware on the new front end group but it is located about 150 miles from here, so I cant look at it! I seem to remember the mount being a rubber pad but I don't remember how thick it was.
Old 05-02-2013, 09:20 PM
GB SISSON's Avatar
GB SISSON GB SISSON is online now
GB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant futureGB SISSON has a brilliant future
Mine involves two big springs with a bolt through them. That's the only thing up front. Could be just the f350 like this though. I could get a photo this weekend.
Old 05-03-2013, 02:17 AM
D57 D57 is offline
Boy, it's been a long time since I took the body off the original frame but I seem to remember just a bolt going through a thick piece of square rubber. It's possible that that wasn't original either! I seem to remember the brackets serving as radiator mounts also. I took the body off the frame almost 20 years ago.
Old 05-03-2013, 05:20 AM
Walston's Avatar
Walston Walston is offline
Walston has a great reputation on FTE.Walston has a great reputation on FTE.Walston has a great reputation on FTE.Walston has a great reputation on FTE.Walston has a great reputation on FTE.
The radiator support bolts to the frame. Everything else kind hangs off it. There may be other pictures in my gallery that help.
Old 05-04-2013, 01:58 AM
D57 D57 is offline
Thanks a bunch, those pics help a lot. Are the radiator mounts and radiator stock on your truck? All that metal is missing on my front end group, but I'm sure it's still intact on the good one I'm going to aquire. Nice detail work by the way. Mine isn't going to be near that nice. Just rattin' it together for now!
Old 05-04-2013, 05:56 AM
Walston's Avatar
Yes all Original. Click on my user name 'Walston' and choose 'View Gallery' for many more pictures.
50 F1 Frame vs 52 F1 Frame bhalemail 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 09-15-2016 09:27 AM
53 F100 radiator support mounting pholmes350 1948 - 1956 F1, F100 & Larger F-Series Trucks 6 06-21-2016 02:41 PM
53 F-100 Frame battery tray mounting pholmes350 1948 - 1956 F1, F100 & Larger F-Series Trucks 8 05-18-2014 10:14 PM
56 F100 Steering box help... JBravo 1948 - 1956 F1, F100 & Larger F-Series Trucks 5 08-10-2012 11:30 AM
Front mount change FT to FE? GLPerry FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 11 02-04-2002 08:50 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
