No speedo,abs light on
Hey everyone,I could use a little help here.
Today while on the way home from a 300 mile round trip my speedo quit,(the odometer still reads numbers but does not change),the abs light is on and the od light is flashing and it was shifting real hard.But it still went into od.
The trans was rebuilt about 40k ago and the fluid looks clean and full.I replaced the sensor in the rear with one from Carquest(they were the only place on the way home) and it is still acting up.
The only code that came up was po500.
Any other suggestions on where to go next????
Thanks,John
Thanks,John
Also check the fuse that feeds power to the speedo. I had the same thing happen to mine when I hooked up my gauges. I tapped into the fuse for my gauges and the back part that the fuse makes contact w/ came out the back of the fuse panel and the fuse wasn't making contact. OD blinking, shifting hard, and no speedo. My ODO didn't work though. I think it was the 18 fuse...top right under the drivers side dash.
IDI guy
19
03-02-2014 05:11 PM
4ced2work
02-02-2004 01:03 PM
