6.4 transmission searching for gear because of DPFR+4.0?
2008 f-250 6.4L 4x4 Ext Cab 108,000 miles.......Two months ago I installed the DPFR+4.0 Cat/DPF delete. The day I installed it, it slammed(not to hard) into 3rd gear at 1/2 throttle. I thought the trans just had to relearn so i took it easy for a week or two. Obviously it was not a relearning issue it hasnt stopped acting funny. Now, it just revs up a bit( like 200 rpms searching for a gear) as its shifting into 3rd or 4th. This only happens when i go to half throttle. It switches gears just fine when i drive like a grampa. I did not notice any of this pre DPFR+4.0. I contacted Gearboxz and they say its not the programmer. I have disconnected both batteries and touched the positive to the negative for 20 minutes to reset computer and it is still doing the same thing. Could it be a sensor? Do you think its related to the programmer? Apparently this programmer does not mess with trans and shift points. I would rather not take it to a trans shop now to rack up a bill if its related to programmer. I read other posts about this but there wasnt a clear answer- sensors, clutch discs.......Thanks in advance for any info.
Couple of things I am thinking.
What ATF are you using and when was the last service?mercon sp, 60,000 miles
Are you running in stock power levels or have you tried in? I'm running it in the +70hp tune. I am going to put my factory flash back on this weekend, test drive it, and retune back to +70hp and see if that helps.
Have you scanned for any codes? Yes, I have an insight. I did pull a thermostat code a long time ago, but I don't think that's the culprit. I believe my t-stat got stuck at some point.
What about putting the cat/dpf back on and retune to stock programming and what happens then?
The damn things runs perfect when I drive normal. Once I go 1/2 throttle from a stop is when all these problems happen. I answered your questions after your comments.
Whenever I am asked to diagnose a trans problem the first step is to ALWAYS remove any tuner. They can cause transmission problems WITHOUT changing anything in the transmission programming. Changing the engine programming is enough to give the transmission fits.
Your trans was fine until you installed the programmer. It is the programmer. Period.
I flashed back to stock and it is not reving between gears. The weird thing is that i can tell it isnt shifting right into 3rd gear with the stock flash. It seems as if the problem is just multiplied with the tuner. It is just shifting rough into 3rd. I guess i have just not noticed it when i was running stock before the tuner. I dont pull much and dont get on it much and the problems dont occur unless you go half throttle. Ive heard of the early model 08 trans having trouble with shifts but I dont know what is causing it. Any suggestions?
If not, the previous owner "probably" had a high horsepower tune that Damaged the Tranny.
Tuners are MURDER on Transmissions IMHO
I bought it used. Everything appeared to be original. When I took the dpf off I found no signs of it ever being taken off. It shifts a lot better with factory flash, just a little rough into 3rd. I'm going to flush the tranny soon to see if that helps. I'm just confused as to why it revs up while shifting with the DPFR 4.0. I don't see anyone else having this issue with the programmer and wanted to hear what you guys know about shifting problems with the early model 5r granny's.
