Spacer with Nipple for 4 bbl carb - Ford Truck Enthusiasts Forums
WTB - Parts & other Want to buy parts/accessories/tools.
Old 05-01-2013, 08:27 PM
HillBillyBuddha HillBillyBuddha is offline
HillBillyBuddha is starting off with a positive reputation.
my 66 F250 has a spacer between the 2bbl carb and original intake. This spacer has a nipple that connects a hose to the passenger side valve cover vent.
I am installing a 4bbl carb on a Edelbrock intake manifold. So I guess I'll be needing the spacer with the valve cover vent hose nipple that is for the 4 bbl carb.
Anyone have such a thing???
Thanks,
Joel
Old 05-10-2013, 09:02 AM
wdfp wdfp is offline
wdfp is starting off with a positive reputation.
I think I have one like you describe but don't know what year its from, I'll check this weekend. If thats for the pcv the carb should have a hookup for that already. I'll check and get back to you though..
Old 05-20-2013, 10:06 PM
81Bronk36 81Bronk36 is offline
81Bronk36 is starting off with a positive reputation.
did you ever find one of these? I may have a 4 hole one with a 1/2 bolt filling a hole that I would assume you can put a nipple in it.
Ford 302 - 2bbl to 4bbl conversion questions Rusty_S Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 5 06-22-2016 08:52 AM
Vapor lock - fuel boiling in carb swolh 1973 - 1979 F-100 & Larger F-Series Trucks 27 02-08-2015 11:45 AM
Heater Contro Valve Set Up D & D 1967 - 1972 F-100 & Larger F-Series Trucks 2 09-28-2014 06:24 PM
Coolant cooled carb spacer xjvince FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 9 08-21-2013 10:56 PM
During carb change found oil under spacer hooler1 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 4 03-30-2013 02:27 PM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
