Can you tell me if this is a stock timing set? - Ford Truck Enthusiasts Forums
Old 05-01-2013, 11:25 AM
voodoolord voodoolord is offline
voodoolord is starting off with a positive reputation.
Ive been researching the timing set info while Im replacing my water pump. I cant tell if this is a stock pre 72 timing set or an aftermarket single roller or if its pre 72 at all. I have not set it to tdc on cylinder one yet but noticed the mark on the crank is aligned with the keyway. Anyone recognize this set?
Old 05-01-2013, 12:28 PM
Oops I forgot to post the pic. After looking at other pics it looks to me like the pre 72 crank gear. Any other opinions?
Old 05-02-2013, 11:25 AM
Maybe I posted this in the wrong place?
Old 05-02-2013, 12:08 PM
mark a.'s Avatar
mark a. mark a. is offline
mark a. has a great reputation on FTE.mark a. has a great reputation on FTE.mark a. has a great reputation on FTE.mark a. has a great reputation on FTE.
If the cranks keyway is right in line with the cog then it's zero.
Old 05-18-2013, 11:32 PM
wtroger wtroger is offline
wtroger is gaining momentum as a positive member of FTE.wtroger is gaining momentum as a positive member of FTE.
It is a straight up set (no retard). But the style is early model (not a roller chain)
Any tricks for removing a Dana 60 axle shaft seal? voodoolord 1973 - 1979 F-100 & Larger F-Series Trucks 4 07-14-2015 10:45 AM
100$ intercooler! lpzd 1994.5 - 1997 7.3L Power Stroke Diesel 13 07-04-2015 02:23 AM
08 Tow Mirrors 7 wire situation. oHFire Electrical Systems/Wiring 1 07-12-2014 06:33 PM
New Restoration Product Coming Soon- Gauge Cluster Decals theastronaut 1961 - 1966 F-100 & Larger F-Series Trucks 14 08-25-2013 10:57 AM
New Look for the 04.... LadderDogV10 1999 to 2016 Super Duty 9 05-15-2013 05:56 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
