Driving with smog pump belt removed? - Ford Truck Enthusiasts Forums
Old 05-01-2013, 10:00 AM
Rovernut's Avatar
Rovernut Rovernut is offline
Rovernut is gaining momentum as a positive member of FTE.Rovernut is gaining momentum as a positive member of FTE.
One of my pumps finally siezed.
Is there likely to be any damage to anything by driving the truck with the belt removed?
1985 F-250 w/460 and dual smog pumps.
Old 05-01-2013, 11:15 AM
bullet2monkey bullet2monkey is offline
bullet2monkey is starting off with a positive reputation.
I have a 1983 f350 460 with a single smog pump, I.believe, and it hasn't had a belt on it since I bought it. I plan to take all the smog stuff off eventually, but haven't gotten around to it. I think removing the smog stuff with the belt would be a good move, more power and gas mileage too! Just my two cents, I could be wrong, but I've seen no signs of damage to anything.
Old 05-01-2013, 11:52 AM
Rovernut's Avatar
Thanks. I just called the local Ford service dept and they seemed to think there was no issue either.
Old 05-01-2013, 11:12 PM
weskan weskan is offline
weskan is starting off with a positive reputation.
My 1981 F150 w/302 had the belt taken off the air pump a long time before I got it. The metal tube that bolted on to the back of the head had rotted out and resulted in a big exhaust gas leak and it was noisy. The PO complained about that and the smell of exhaust in the cab, so he was afraid of taking it more than 10 minutes drive outside of town.
This would only be a problem if you never took off the air injection manifold at the point where it enters the head or exhaust manifold and plug it. Otherwise, no problem with not running the air pump.
Old 05-02-2013, 01:45 AM
joshofalltrades joshofalltrades is offline
joshofalltrades has a good reputation on FTE.joshofalltrades has a good reputation on FTE.
the air pump's only purpose is to help the catalyst to start working faster when cold. so if the cat is already missing, then the air pump has absolutely no purpose in your engine bay. regardless, you won't hurt anything by running without it, except maybe if you're running down to take an emissions test
Old 05-02-2013, 05:35 AM
Rovernut's Avatar
Just to be clear, I was asking about doing nothing but removing the belt for the time being, but leaving everything else as is.
I'm pretty sure the smog pumps were to help with sort of a post combustion as the exhaust leaves the manifolds. Air injection systems were used before the introduction of cats. My truck doesn't look like it ever had cats either.
Old 05-02-2013, 06:07 AM
chillman88 chillman88 is online now
chillman88 is starting off with a positive reputation.
The way I understand it, as long as the pulley for the smog pump is the only item driven by it's belt, you should be fine. I was under the understanding that I'd be fine with my setup (pump is missing) but according to weskan I could be wrong and the tubes need plugged? In your case you should be fine though as your pump is still physically connected to the plumbing, just not pumping. I'm pretty sure I'll be fine though since my check valves are still in place, they are designed to stop backflow anyway.
Old 05-02-2013, 07:14 AM
Rovernut's Avatar
Ah! So there are check valves. I was wondering about that.
Yeah, only things on the belt. Crank drives the alternator via one groove, other groove on the alternator pulley drives the two smog pumps.
Old 05-02-2013, 08:19 AM
On my pickup, the tube was rotted after the check valve. The metal of the injection system wasn't designed to handle exhaust gases and heat, so without fresh air going through it, it eventually developed a leak.
I don't know how long it took, could have been a 20 year process, but $10 for some plugs cured the leak vs over $100 to replace the bad components.
Old 05-02-2013, 09:39 AM
1986F150six 1986F150six is offline
1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold
I have read that driving without the air pump functioning will shorten the life of the catalytic converter [if so equipped] which is downstream of the extra air [some have another converter closer to the engine]. This might lead to plugging of the converter.
Removing smog pump? FordYoungGun35 1987 - 1996 F150 & Larger F-Series Trucks 5 08-20-2012 07:24 AM
belt routing help! ericford1984 Ford Inline Six, 200, 250, 4.9L / 300 5 03-22-2012 11:16 AM
351w smog removal polky Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 0 09-11-2009 03:48 PM
Smog pump removal JBronco 1978 - 1996 Big Bronco 4 12-02-2002 05:34 PM
Serpentine Belt routing after removing smog pump? AlM 1978 - 1996 Big Bronco 2 02-10-2001 09:33 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
