BS makes Illinois flowers bloom in May deposit yours here.
05-01-2013, 08:54 PM
Quote:
Originally Posted by
CLINT-THE-GREAT
My current Crisis people!!!!!
-The Great
You've checked what my thoughts were. ESOF at the hubs and vacuum pump and tank.
05-01-2013, 08:56 PM
fire240
Clint Im thinking it could very well be a vacuum line giving you grief at one of the hubs.
I tried following my vacuum lines down to the hubs, but couldnt feel or see any kind of leak. They are original hubs.
-The Great
05-01-2013, 08:57 PM
Could also be a vacuum leak from the actuator onat the hubs. COuld also be a leak there at the blend door.
05-01-2013, 09:03 PM
CLINT-THE-GREAT
-The Great
Pull the ESOF lines off of the hubs and plug. Try it, if it still blowing through defrost its not the hub seals. Might be a small split in the line that you can't feel or see.
05-01-2013, 09:06 PM
Does the engine have to be running for the vacuum pump to run?
05-01-2013, 09:09 PM
KOESTNER
No, you can KOEO (key on engine off) and the pump starts
-The Great
05-01-2013, 09:11 PM
Thats cool Clint. Im use to the larger diesels where it is belt driven off of the alternator.
05-01-2013, 09:12 PM
CLINT-THE-GREAT
-The Great
Good. That eliminates the noise. Just need a quiet area to listen.
05-01-2013, 09:14 PM
fire240
No worries Shaun, i dind't even know until this happened. It's an electrical pump.
-The Great
05-01-2013, 09:16 PM
KOESTNER
I tried, all that was running was the Vacuum pump but i didn't hear any hissing.
-The Great
05-01-2013, 09:18 PM
i still say its a bum actuator
05-01-2013, 09:19 PM
-The Great
05-01-2013, 09:20 PM
that or a dirty electrical contact... alot of people dont realize the switch itself isnt just vacuum controlled... it has an electrical component that talks to the computer, blowers, and compressor as well... shorts in that part of the switch can cause similar issues...
