Help me figure out what I have... 01 F-250 with S/C 5.4L
So... I bought a rusty truck (from Michigan, I'm in SC) that has a 5.4l s/c (supercharger appears factory based on the valve cover label). The po claims that he worked for Ford and when the stock 5.4 went out on him three years ago, he bought the s/c engine from the factory and put it, along with a new tranny (body lift to accommodate, etc). He said that they pulled every 75th engine off the line and checked them for quality control, so this was a "zero mileage" engine. I don't know enough about engines to say that he wasn't being upfront with me, but he says this is a lightning motor. Obviously, the lightning model truck was not in production three years ago....
So, is this possibly a crate motor? Is it from whatever 5.4 s/c truck they may have had in production three years ago? All I know is that it is smoking' fast for such a big truck and it seems to run great. My reason for asking is for when I need parts, tuner, etc. I would like to know what I'm looking at...
Thanks for the help!
it's a 5.4 block, it has 2 valve heads...
what I'd be worried about is it being a n/a motor (higher compression cast pistons VS lower compression forged pistons)
all in all it loks well put together, BUT I have no idea if the ECM was tuned via an aftermarket device OR a factory reflash
If it is a stock NA 5.4 he added the eaton to you need to get a tune on it.
If you go WOT with the stock NA motor you are going to go way lean and burn a piston.
We have pulled many Eatons off Gen 2 lightnings and replaced with Whipples. the used Eatons are going for under $400.00.
You have been given some good advise. find the block SN and find out if it was a NA motor or not. If it was a NA motor and he just added the Eaton get it to a tuner. You may need to go with bigger injectors depending on how much boost you are pushing. If the truck does not have a boost gauge get one.
Sorry can't tell you exactly what you have but like A**holes everybody has an opinion and above is mine.
I would love to have a lightning motor in my 02 F350! I have the ZF6, so no trans worries. I have a Whipple s/c on my Excursion, and as soon as we leave Alaska and get to the lower 48, I need to have a tuner check it over, and get rid of the boost-a-pump, and got to a larger fuel pump and larger injectors, and ditch the Whipple box, for a custom tune. That way when I have any problems I can go to a tuner since Whipple no longer supports much for this system.
Good luck on the ID. Is your SD an auto?
Garry in Kodiak.
Garry in Kodiak.
1954wrecker
06-16-2018 08:42 PM
Cabledude
08-30-2016 05:09 PM
onelow90
01-11-2011 09:15 PM
