Help me figure out what I have... 01 F-250 with S/C 5.4L - Ford Truck Enthusiasts Forums
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's
Old 04-30-2013, 07:10 PM
Guitargene82 Guitargene82 is offline
Guitargene82 is starting off with a positive reputation.
So... I bought a rusty truck (from Michigan, I'm in SC) that has a 5.4l s/c (supercharger appears factory based on the valve cover label). The po claims that he worked for Ford and when the stock 5.4 went out on him three years ago, he bought the s/c engine from the factory and put it, along with a new tranny (body lift to accommodate, etc). He said that they pulled every 75th engine off the line and checked them for quality control, so this was a "zero mileage" engine. I don't know enough about engines to say that he wasn't being upfront with me, but he says this is a lightning motor. Obviously, the lightning model truck was not in production three years ago....
So, is this possibly a crate motor? Is it from whatever 5.4 s/c truck they may have had in production three years ago? All I know is that it is smoking' fast for such a big truck and it seems to run great. My reason for asking is for when I need parts, tuner, etc. I would like to know what I'm looking at...
Thanks for the help!
Old 04-30-2013, 08:44 PM
Old 04-30-2013, 08:49 PM
Old 05-01-2013, 08:08 PM
06malibu's Avatar
06malibu 06malibu is offline
06malibu is starting off with a positive reputation.
Id look for vin numbers on the block. But non the less thats a pretty rare truck
Old 05-19-2013, 02:01 PM
stoffer's Avatar
stoffer stoffer is offline
stoffer is starting off with a positive reputation.
Quote:
it's a 5.4 block, it has 2 valve heads...
what I'd be worried about is it being a n/a motor (higher compression cast pistons VS lower compression forged pistons)
all in all it loks well put together, BUT I have no idea if the ECM was tuned via an aftermarket device OR a factory reflash
Old 05-28-2013, 09:58 PM
Gen 1 driver Gen 1 driver is offline
Gen 1 driver is starting off with a positive reputation.
Appears to have the factory Eaton SC in it. If it was in fact a lightning a lightning motor and he had it tuned for the Lightning motor you are in good shape.
If it is a stock NA 5.4 he added the eaton to you need to get a tune on it.
If you go WOT with the stock NA motor you are going to go way lean and burn a piston.
We have pulled many Eatons off Gen 2 lightnings and replaced with Whipples. the used Eatons are going for under $400.00.
You have been given some good advise. find the block SN and find out if it was a NA motor or not. If it was a NA motor and he just added the Eaton get it to a tuner. You may need to go with bigger injectors depending on how much boost you are pushing. If the truck does not have a boost gauge get one.
Sorry can't tell you exactly what you have but like A**holes everybody has an opinion and above is mine.
Old 10-18-2013, 12:25 AM
garryk6's Avatar
garryk6 garryk6 is offline
garryk6 is a splendid one to beholdgarryk6 is a splendid one to beholdgarryk6 is a splendid one to beholdgarryk6 is a splendid one to beholdgarryk6 is a splendid one to beholdgarryk6 is a splendid one to beholdgarryk6 is a splendid one to behold
Quote:
Originally Posted by Guitargene82 View Post
I would love to have a lightning motor in my 02 F350! I have the ZF6, so no trans worries. I have a Whipple s/c on my Excursion, and as soon as we leave Alaska and get to the lower 48, I need to have a tuner check it over, and get rid of the boost-a-pump, and got to a larger fuel pump and larger injectors, and ditch the Whipple box, for a custom tune. That way when I have any problems I can go to a tuner since Whipple no longer supports much for this system.
Good luck on the ID. Is your SD an auto?
Garry in Kodiak.
Anyone here with a Supercharged X??? Breaker 1-9 Excursion - King of SUVs 11 04-13-2012 04:38 AM
5.4 tuner magnumdd 1999 to 2016 Super Duty 0 06-08-2011 08:35 AM
Thinking really hard about OBX LT setup off ebay BURNSTOUGHFORD 1997 - 2003 F150 10 04-09-2010 01:20 PM
hesitation on take off EDDIE7664 2004 - 2008 F150 3 10-02-2009 05:10 AM
73-79 100/150 SuperCab ShortBed IATSE44 1973 - 1979 F-100 & Larger F-Series Trucks 11 04-02-2007 06:50 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
