serpentine belt diagram 90' f150
Old 07-20-2002, 08:41 PM
edgarpoe27's Avatar
edgarpoe27
edgarpoe27 is offline
Post serpentine belt diagram 90' f150
I was wandering if anyone could describe the order in which I need to put my serpentine belt on? Over or under which pully's? My diagram on the front of the truck has worn off and my Haynes doesn't have the picture or the order of it. I would have kept track of it if I had removed it, but my fan flying off assisted in it's removal and the removal of half my radiator. Any help would be appreciated.
Old 07-20-2002, 09:48 PM
DeGideo's Avatar
DeGideo
DeGideo is offline
A factory 1990 F-series/Bronco shop manual should have these diagrams.Although this doesn't help you out now,I think Ford still sells those underhood belt decals,so next time you have to change the belt,you'll have the diagram in front of you.If they don't have one,you might try contacting autokrafters.com If you don't have a 1990 shop manual,you can contact helminc.com to get a new one.I've seen some on ebay,too,recently.Hope this helps.
Old 07-20-2002, 11:26 PM
nitro94's Avatar
nitro94
nitro94 is offline
Any auto supply source that has Gates belts has the diagram listed in the belt catalog.
Old 07-21-2002, 02:24 AM
BlueMeanie's Avatar
BlueMeanie
BlueMeanie is offline
Hello
This is for my 1995, but it's probably the same.
http://www.geocities.com/bwright36/belt.gif
Old 07-26-2002, 12:06 AM
pross's Avatar
pross
pross is offline
Old 07-26-2002, 11:46 PM
edgarpoe27's Avatar
edgarpoe27
I appreciate the help everyone and I will try to get a shop manual. Is the manual for my specific truck because I know half the stuff in a Haynes or Chilton is wrong. Anyhow I stopped a guy in Bass Pro parking lot and asked to look under his hood. I don't think I'll forget the order of which the belt goes again though. Thanks
B-Ryan 02
08-14-2023 05:40 PM
Wakeboarder141
1978 - 1996 Big Bronco
12-16-2021 06:46 AM
Justin Jones
02-11-2018 10:06 PM
tramp
13
05-31-2008 11:23 AM
ottr1967
02-21-2007 03:26 PM
Quick Reply: serpentine belt diagram 90' f150
