360 stroker - Ford Truck Enthusiasts Forums
360 stroker
Old 04-30-2013, 03:41 PM
ford351m ford351m is offline
ford351m is starting off with a positive reputation.
360 stroker
Has anyone stroked there 360 to a 390 and is it worth the extra money
Old 04-30-2013, 04:34 PM
jowilker's Avatar
jowilker jowilker is offline
jowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to behold
ford351m Welcome to FTE & the Bumpside forum
Yes sir many times. The 360 is a 390 bore block engine with a 352 rotating assembly. All you need is a 390 crank and rod set with new pistons properly sized and you are all set. Piece o cake.
Add an RV cam, shorty headers, a small 4 barrel carb and you will have a stump puller. Stay at 600cfms or smaller on the carb.
John
Old 04-30-2013, 07:19 PM
JEFFFAFA's Avatar
JEFFFAFA JEFFFAFA is online now
JEFFFAFA has a brilliant futureJEFFFAFA has a brilliant futureJEFFFAFA has a brilliant futureJEFFFAFA has a brilliant futureJEFFFAFA has a brilliant futureJEFFFAFA has a brilliant futureJEFFFAFA has a brilliant futureJEFFFAFA has a brilliant futureJEFFFAFA has a brilliant futureJEFFFAFA has a brilliant futureJEFFFAFA has a brilliant future
Quote:
Worth it? Check this out. Ford's 390 came from the factory with real close bore and stroke numbers as what the Bow Tie Brigade now build their 383 with. They are all so puffy chested about it being a torque monster. We beat them by DECADES!
Old 04-30-2013, 10:17 PM
Thanks for the info, and would 750 cfm Carb work if I put a mild performance cam in?
Old 05-01-2013, 05:05 AM
jowilker's Avatar
Way too much carb for that engine. Better to keep it to 600 or less, 5-550 cfm would be better. It will run the 750 but not burn the gas.
John
Old 05-01-2013, 10:46 AM
JEFFFAFA's Avatar
Quote:
John
351M.
jowilker is absolutely correct. If your 750 is a vacuum secondary with a black or brown spring so the 390 never sees the whole 750 CFM kinda maybe. But I stand pat with jowilker. Too much carb equals low efficiency. Bad gas mileage. Low power.
Old 05-01-2013, 03:41 PM
boo-yaa138's Avatar
boo-yaa138 boo-yaa138 is offline
boo-yaa138 has a great reputation on FTE.boo-yaa138 has a great reputation on FTE.boo-yaa138 has a great reputation on FTE.boo-yaa138 has a great reputation on FTE.
i agree with above. 390 is much better the a 360. not only performance but believe it or not it will even get better mpg if you tune it right and put the right carb and exhaust on.
Old 05-01-2013, 07:08 PM
MIKES 68 F100's Avatar
MIKES 68 F100 MIKES 68 F100 is offline
MIKES 68 F100 has a good reputation on FTE.MIKES 68 F100 has a good reputation on FTE.MIKES 68 F100 has a good reputation on FTE.
i'll disagree about the 750 being to much , i've had three carbs on my mild build 390
600 vac sec, 650 double pumper and the 750 vac sec
600 was good , 650 bogged 750 runs like a scalded dog
Old 05-01-2013, 07:32 PM
JEFFFAFA's Avatar
Cool that you got one to work. I'm sure the 10:1 compression ratio helped ya. For my own info, do you remember which color spring is in your secondary diaphragm housing?
Old 05-02-2013, 09:17 AM
actually I have the quick fuel adjustable secondary kit . makes tweeking alot easier .
http://www.ebay.com/itm/Quick-Fuel-Holley-Carburetor-Adjustable-Vacuum-Secondary-Kit-Quick-/190814536296?pt=Motors_Car_Truck_Parts_Accessories&hash=item2c6d6ec268&vxp=mtr
Old 05-02-2013, 09:35 AM
68cabby's Avatar
68cabby 68cabby is offline
68cabby is starting off with a positive reputation.
That quick change is a lifesaver!
what is the difference between a rv 360 and a normal 360 68 f250 1967 - 1972 F-100 & Larger F-Series Trucks 11 02-04-2015 09:56 PM
360 Performance sparky 1973 - 1979 F-100 & Larger F-Series Trucks 2 12-27-2002 10:57 PM
Door Cracks Curtis360 1997 - 2003 F150 10 09-08-2002 08:07 PM
360 or 390? lastchance 1973 - 1979 F-100 & Larger F-Series Trucks 3 12-14-2001 07:40 PM
360 to 460 fozzy 1973 - 1979 F-100 & Larger F-Series Trucks 3 03-03-2001 07:37 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
