70 body put on 73 frame
Hey guys, I have a 1970 f100 Sport Custom and I have a 73 rolling chassis complete with motor tranny, etc. The swap seems pretty straight foward except for the bed. From what I have read the bed mounting holes are on the inside of the bed rails on the 70 and the mounting points on the 73 frame dont match up. Any suggestions on how to reinforce the new holes I have to drill to avoid warping the bed? Thanks
Boo, Don't know where Jeff got his info. The cab & front clip are bolt hole exchange. If you are going to do it I recommend keeping it all together. Lift it up roll the chassis out and the new one under.
In 73 Ford added 4in to the rear of the cab & behind the mount bolts, so the chassis & wheel base is longer. They also widened the chassis behind the cab along with the rear track. The front track was widened in 65 with the Twins. Your big issue is going to be visual only. You can set the cab/clip as far back as possible, place a little more space between the cab & bed, and get by if you aren't out for eye candy.
Weld plates on the chassis under the old bed holes drill them & bolt the bed using existing holes.
You can do all this dry run if you like but the issue is space between the bed and or rear wheel position in the bed wheel opening.
John
John
*AKA. Can of worms. LOL!
John
John
Is the frame in your truck rusted out and unusable ? That would be the only reason to change frames if you are going to end up changing out the front suspension and modifying the rear too . It would be less work and fit better if you used the correct frame like what's under your truck.____Just my opinion , i try to go the easy way if possible.__
Boo. Sorry if this is a kick in the crotch but I gotta say. John, I've always got a kick out of your on a quiet night hearing the chevys rust. The 1st time I read it I laughed out loud. BUT ON THIS THREAD IT KILLED ME! LMAO!
The chassis the truck is currently sitting on is no good. It is having the first stages of rot on it, I am getting the chassis complete with drivetrain is in near perfect condition. I am able to get this newer chassis for about 100.00 and the cost to repair the orignal would be out of my price range. I'm on a low budget to start this project so swapping the chassis seems to be the better move for me.
JakRak
06-07-2018 08:50 PM
Dblack15NC
18
05-04-2016 05:37 PM
