Universal Fuel Gauge and sender questions - Ford Truck Enthusiasts Forums
Old 04-30-2013, 03:44 PM
Koch85F150's Avatar
Koch85F150 Koch85F150 is offline
Koch85F150 is starting off with a positive reputation.
has anyone used a universal sender and gauge? I have looked for a new sender for my truck but not having much luck and on ebay for $42 i can pickup a universal set just wondering if anyone has used one of these kits?
Old 04-30-2013, 03:59 PM
JayzDaddy's Avatar
JayzDaddy JayzDaddy is offline
JayzDaddy is gaining momentum as a positive member of FTE.JayzDaddy is gaining momentum as a positive member of FTE.
Lmc has the correct ones
Truck Parts and Truck Accessories
Old 04-30-2013, 04:02 PM
Koch85F150's Avatar
Thanks... still looking at the universal set considering that on lmc the factory replacement is double, and the truck is only worth about $800
Old 04-30-2013, 04:09 PM
Franklin2's Avatar
Franklin2 Franklin2 is offline
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
Those universal ones are tricky to install. Your biggest problem will be mounting it in the tank. You will notice it has no pickup for the fuel and no connection for the fuel line. So you will have to cut a new hole in the top of the gas tank to install it.
Then you will have to mount the gauge under the dash. My experience with these are the gauges tend to be "sticky" and overall it doesn't work the greatest(I had one in my 53 f100).
What year and type of engine do you have in your truck? The Ford guages are very reliable, it's the sending units in the tank that gives all the trouble. I have a diesel which has a very oddball type sending unit, and is almost impossible to get, and when you do find one it's like around $200 for it. Some guys with the diesels have actually bought the unit you have in your link, and have taken it and retro-fitted it to the original Ford sending unit. If you like fiddling with stuff and you can't find your particular unit, that may be a route you could take. Just make sure you get the 0-90 ohms unit.
Old 04-30-2013, 04:22 PM
Koch85F150's Avatar
1985 f150 4.9 Carb
Old 04-30-2013, 04:43 PM
JayzDaddy's Avatar
Personally ill spend (and am going to in a upcomming project) the 69.95 for a bolt and go unit. I did find one on autozone.com once but havent found it again. Its a specific key word. I tbink it was about 35 bucks.
Old 04-30-2013, 05:54 PM
Labhound Labhound is offline
Labhound is starting off with a positive reputation.
I replaced the non-working universal set up my Dad put in it with a factory replacement from LMC, now it works.
Old 04-30-2013, 07:41 PM
Franklin2's Avatar
I did some looking, and it seems the local parts stores don't carry them anymore(China is falling down on the job I guess). I looked on RockAuto also.
Old 04-30-2013, 10:25 PM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
Originally Posted by Koch85F150 View Post
1985 F150 4.9 Carb
THREE possible sending units!
17 gallon (E5TZ-9275-H) or 19 gallon (E5TZ-9275-G) mid-ship fuel tank or 19 gallon (E5TZ-9275-C) aft axle fuel tank?
Old 04-30-2013, 10:47 PM
JayzDaddy's Avatar
17 gallon?? Thought there was only 16 & 19 gallon.
Old 04-30-2013, 10:54 PM
Do you see a 16 gallon fuel tank sending unit listed for your application?
Old 04-30-2013, 11:11 PM
JayzDaddy's Avatar
Maybe im mixing something else up with this. Somehow for the last year i thought i had a 16 gallon tank.
Old 04-30-2013, 11:15 PM
JayzDaddy's Avatar
Nope. Actually i was going by lmc page. They list a 16 & 19 replacement size. I ASSuMEd that was a oe size and style replacement.
460 Adjustable Fuel Pressure Regulator, will this work? ponykilr 1987 - 1996 F150 & Larger F-Series Trucks 18 06-24-2015 11:43 AM
Gauge Pod Shadowrider123 1961 - 1966 F-100 & Larger F-Series Trucks 1 08-28-2014 03:10 PM
Sinister "Black Diamond" Shaneb75 6.0L Power Stroke Diesel 12 08-23-2014 10:27 AM
suitable widowmaker replacement? jmtbiggin Large Truck 6 12-16-2013 10:13 AM
factory hubs riverguideguy 1973 - 1979 F-100 & Larger F-Series Trucks 8 03-18-2013 10:14 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
