wires to coil
04-30-2013, 01:22 PM
wires to coil
Does the wire that comes from the cab (I'm guessing from the ignition switch) top the coil, go to the negative or the positive terminal on the coil?
Thanks
Joel
04-30-2013, 04:28 PM
on
i don't know what vehicle you're working on, but the wire from the ignition switch would go to the positive side of the coil, and the distributor or module goes to the negative side.
04-30-2013, 06:14 PM
Wire to the + of the coil, and this wire has a special piece of resistance wire in it if you are running the stock Ford points or duraspark system. These systems run about 9v on the coil when the engine is running.
Jeff K
18
11-04-2013 11:25 AM
johninraleigh
Electrical Systems/Wiring
10-17-2007 10:01 AM
velcro7279
03-27-2007 08:18 PM
jamtak
10-11-2003 10:20 AM
havinfun
09-27-2003 08:48 PM
