ZF-5 for 1979 F100 302 V8?.
Old 04-30-2013, 09:45 AM
Valdez904's Avatar
Valdez904
Valdez904 is offline
I bought a ZF-5 out of a 1991 F250 with a 302 and it should be a direct bolt up to my 302 but the flywheel pressure plate throw out bearing everything but the clutch plate is bigger or the size is off is there anyway around that so I can run this small bolt zf-5 on my 79 302?.
Old 04-30-2013, 10:48 AM
jas88's Avatar
jas88
jas88 is offline
The ZF uses a hydraulic clutch, you would need all those parts (clutch, pp, to bearing) for the 91. Also you will have to modify your firewall to accept the clutch master cylinder.
Old 04-30-2013, 04:11 PM
Valdez904's Avatar
Valdez904
The flywheel for a 91 and a 79 are different sizes but if I buy all those parts for the 1991 tranny that's all ill need to run that tranny on my 1979 F100 302.
Old 04-30-2013, 05:53 PM
Canus's Avatar
Canus
Canus is offline
Make sure you get the correct balance flywheel for your engine. 79 is probably 28 oz. while the 91 would be 50 oz.
Vean555
15
01-16-2013 09:40 PM
topfuel
05-15-2012 03:16 PM
diablogreg
08-02-2004 12:22 PM
2bad79s
06-27-2003 11:49 PM
badboyina67
05-02-2002 02:48 PM
Quick Reply: ZF-5 for 1979 F100 302 V8?.
