1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
2012 Illuminated Running Board Courtesy Light wiring
Old 07-15-2016, 10:27 AM
Trophy_23's Avatar
Trophy_23
Trophy_23 is offline
Thanks! I wonder if its the same on an 07. I would love to do this.
Old 07-15-2016, 03:30 PM
Hedgehog1's Avatar
Hedgehog1
Hedgehog1 is offline
2007 superduty would be black w/blue stripe in either kick panel or sill plate. These harnesses go down the kick panel and go toward the rear of the truck. This wire will function as a dome light so it will energize during unlock and when any down is opened. This is not a puddle light, I couldn't find that wire listed on my database. I would assume that the previous post I did would work on 2011-2016 models only.
Old 07-15-2016, 10:54 PM
Trophy_23's Avatar
Trophy_23
My problem with doing this is the dome light doesnt come on with the remote unlock, only my running/cab lights.
Old 07-15-2016, 11:20 PM
Hedgehog1's Avatar
Hedgehog1
Do you have factory remote entry or aftermarket? If it is aftermarket, either it didn't have that option which I doubt or the feature wasn't hooked up. Most aftermarket remote entry/alarms or remote starts have a negative dome light supervision output.msince ford has a positive dome light circuit, it requires a relay to hook it up.
Old 07-15-2016, 11:28 PM
Trophy_23's Avatar
Trophy_23
Yup, aftermarket. I am a little annoyed with how it is hooked up, because I can't use my key pad. Well, I can use it to unlock the door, but the alarm goes off.
Old 07-16-2016, 10:38 PM
Hedgehog1's Avatar
Hedgehog1
That is normal. There is no arm/disarm inputs on the aftermarket alarm that could be wired to the Oem keypad.
Old 10-22-2016, 12:48 PM
Jerefoy's Avatar
Jerefoy
Jerefoy is offline
Originally Posted by TerraTug
A little background first: I installed aftermarket running boards with courtesy lights i wanted to activate with the key fob, doors, essentially anything that would cause the interior/cargo light to trigger. Some models are prewired for running board lights with connectors on the frame rails ready to go, some are not and i do not know for sure which models are. Ours is not. So I wired them to the gray/purple wire in the door sill labeled courtesy light and after a few days, the whole circuit shut down meaning no more interior lights, cargo lights, or running board lights. Checked the fuse and everything else I could think of which was all fine. So i did some research and this is what i found.
The courtesy lights and running boards (also sometimes noted as "puddle lights," inconsistently) run off the same fuse (15A) BUT THEN run through the BCM in 3 different channels: Puddle Lights (purple), Courtesy Lights (gray/purple), and a channel labeled as "unused". Each channel has an AMP tolerance that is monitored by the BCM. When the amps through the circuit are too high (signaling an overload or short) for too long, the BCM shuts down the channel which can only be reactivated by running a check through the OBDII port, and will permanently deactivate after a certain number of instances at which point the BCM must be replaced. Personally, i think this is kind of a crappy setup as the fuse should be oriented in a way to protect the BCM but i'm sure the current setup is cheaper and easier for FORD and still complies with whatever fire preventative/saftey regulations to which they must adhere.
One may be able to get by running some LEDs off the circuit, especially if LEDs are added to the interior and cargo lights to reduce overall current draw, but I'd avoid it all together. The puddle light is the lead from which the running boards should be run. The wire is purple (VT) and runs in the same harness as the courtesy lights through the door sills on both sides. But be careful, on certain models, there is a prewired connector under the cab just forward of the bed on the frame rails, ready to go and there is no need to tap the wire in the door sills. If you do not have this prewired connector, DO NOT CONNECT ANYTHING TO THE PURPLE WIRE RUNNING THROUGH THE WIRE BUNDLE ON THE FRAME RAIL UNDER THE CAB. It is an identical purple wire, but is twisted in a helix pattern with another wire and these together are the ABS sensor leads. Messing with them will have negative consequences. On models without the prewired connectors, the "puddle light" lead does not extend past the engine bay under the truck, it terminates in the engine bay at the harness connector.
The puddle light circuit runs the factor available illuminated running boards that have 4 wedge type bulbs. I don't know how many amps the circuit can handle before it will shut itself down but if you run 4 or less conventional bulbs of the same or less watts or a bunch of LEDs, you'll be fine using this source without overloading the circuit and shutting down the BCM.
A last word of warning, some but not most manufacturers make LED replacement bulbs for stock filament bulbs that incorporate a resistor so they draw ~ the same amps as to not throw a code for a burned out light, sometimes labeled as CAN compatible. These do NOT draw less current and should be treated like a filament bulb. They also heat up as much as filament bulbs due to the resistor.
Hope this helps someone out there avoid some serious agitation!
You are awesome for this write up. Was looking to do the same in '12F250KR. Will research and search before proceeding. THANK YOU!!!
Old 03-22-2017, 10:11 AM
-brent's Avatar
-brent
-brent is offline
I tapped some LEDs to my cargo light and after about 4 months my cargo light and interior lights do not come on. My puddle lights still work though. Thanks for the tips, I was going nuts trying to find a blown fuse-- and they weren't blown!
Old 06-08-2017, 12:11 AM
NHBILL's Avatar
NHBILL
NHBILL is offline
7th Gear
Originally Posted by Hedgehog1
I installed the full length led strips above the running boards a few months ago on my 2016 crew cab lariat. It had the connectors on the frame so it was easy. My buddy liked it so much he wanted them on his 2012 supercab XLT. His did not have the factory connectors so I found the correct wire for the puddle lights at the bcm in the passenger kick panel. It is located in a black 16 pin connector. This connector is one of the closest to the firewall and I believe the lowest connector also when looking at the bcm.the wire color is purple and it is pin 1 in the 16 pin connector.
Looks like pin 1 of C2280C from the image above yours. Are the lights still working with no problems?
Old 06-08-2017, 12:15 AM
NHBILL's Avatar
NHBILL
NHBILL is offline
7th Gear
Originally Posted by cursedag
Hello- I have a 2011 F250. I followed the wiring diagram in the linked docs in this post, but my vehicle BCM cables connect to the power distribution unit not the BCM unit. I have a BCM unit, but I couldn't find the correct wiring diagram from the BCM to the power unit (dont know what its called).
Can anyone offer any advice on the wiring connections between these two units?
I overloaded the BCM channel for the dome light and am replacing it. I would like to wire in a relay into the wire that powers the dimmer for all 3 channels. The relay will not run properly on the "dimmed" wire.
Old thread, but a dimmed circuit can trigger a relay; a capacitor can be used to keep the relay happy.
Old 09-04-2017, 09:53 PM
Accessory Man's Avatar
Accessory Man
Accessory Man is offline
Am I going to have this issue with the BCM on my 2005 or is this just a issue with newer trucks?
Buxten
2017+ Super Duty
15
03-04-2018 06:12 PM
Ford Truck Racer
21
04-09-2006 09:44 PM
blueovalnv
Electrical Systems/Wiring
11-20-2004 01:39 PM
ccbrown518
10-07-2003 09:14 PM
Ultra Blue
1997 - 2003 F150
03-29-2003 12:46 AM
Quick Reply: 2012 Illuminated Running Board Courtesy Light wiring
