door inner trim interchange?
I have '95 E-350 7.3 that I've been mechanically restoring to specs, time to start on the creature comforts, I want to start with new inner door panels. Does anybody know what newer panels will interchange with the OBS? My panels are all cracked, broken and filthy and all the '95 panels I see on ebay are not much of an improvement, I do see newer ones that look like they'd work but its an expensive risk. Anybody on here done this before?
Thanks, Oj
Thanks, Oj
If you have access to a self serve junkyard (Pick-N-Pull etc.) with a good selection of vans, you can test fit panels across various model years in the yard. These panels are about $30 so you can even bring one home to test and not spend a fortune. Our Pick-N-Pull will let you return parts for exchange if they don't work or fit properly.
Other than JY stuff, If your inner door panels are still intact, go to home depot, Lowes, whatever, buy some thin Masonite and use your old panels as a template, then you can either strip your old vinyl off and reuse it or go to the local Hobby Lobby or Michaels buy some new stuff and make them the way you want them.
tjh7167
04-05-2021 08:49 AM
