2008 exped 5.4l , 70,000 , do i need spark plugs? - Ford Truck Enthusiasts Forums
2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Old 04-29-2013, 11:12 PM
Coronaglen Coronaglen is offline
Coronaglen is starting off with a positive reputation.
i was at the dealer. we only have 70k on the expedition but live in southern california. my wife drives it only to work, three days a week. we do not drive a lot on it. normal stuff.
we do not tow either. it is 2wd.
dealer tells me we were supposed to change the spark plugs at 60k because we are in an extreme driving area. isnt that more the driver than the area?
also, told me i needed to get some throttle header service done and my transmission fluid replaced. which is sealed and the owner manual says do it at 100k.
but the spark plugs are 525. another ford dealer said 680. then i read about everyones issues about spark plugs breaking during removal and you have to pay more to get them out.
should i negotiate before i go in and make sure they cover any issues? any suggestions from anyone in southern california, inland empire are?
am i being ripped off?
thanks
Old 04-30-2013, 12:40 AM
montecarlo31 montecarlo31 is offline
montecarlo31 is starting off with a positive reputation.
Well after reading the post I'd say your not going to tackle any of this yourself. I'd also say you actually drive this vehicle like most others, looks like about 14,000 miles per year give or take. The link below should help you. Read it, learn what for advises, figure out your driving habits. I would say, Southern Cal to AZ to TX to FL and GA would be in my book heavy service use areas. Your running in 90 degree heat most of the year and heat breaks down fluids and lowers lubricity. 525 bucks for plugs doesn't seem bad being you are in Cali and nothing is cheap there. I've knocked them out on my old 5.4 in less than two hours but I don't think your a DIY guy. So figure 100 bucks an hour for labor and whatever plugs are, 5 or 6 bucks each?
I highly advise doing the trans every 30K miles, I did this on my company expedition and will do it on my personal one. The trans is not "sealed" it's check plug is simply located on the side and does not include a dipstick.
http://www.motorcraftservice.com/pub.../08frdmg3e.pdf
Cliffs:
Change trans fluid.
Flush brakes if you haven't yet.
Flush rear diff
Check coolant life
Change plugs only if unit is running poorly.
Old 04-30-2013, 09:59 AM
johnkn johnkn is offline
johnkn is gaining momentum as a positive member of FTE.
In February, my local Ford dealership charged me $19.16 each for the sparkplugs they replaced on my 2005 Expedition.
Old 04-30-2013, 10:16 AM
jimb726 jimb726 is offline
jimb726 is starting off with a positive reputation.
Well first off, you have a 2008, depending on when yours was built, you may not have the spark plug issue. Ford changed the heads and the plugs in 2008 to address the issue. Where I live the dealership charges $399 to replace the plugs and that includes labor to remove broken plugs. If you are a DIY guys there are plenty of threads on ways to handle these plugs. They are expensive plugs, figure $16 to $20 each depending on your dealer. If you are comfortable removing a coil pack, do so and look at the boot (the part inside the head, connecting to the plug) if it is brown you have the new neads and plugs and should not have issues with plugs breaking off. If the boot is black you have the older style heads and plugs.
Old 04-30-2013, 10:17 AM
Quote:
hopefully they gave you some lube to go with that bill. I just logged into my fleet account and checked our pricing, just a hair under 10 bucks each.
I'd be interested to see what they are charging him per plug. Plus he should be changing his fuel filter too since CARB requires it to keep your emissions warranty in tact.
Old 04-30-2013, 05:13 PM
berry1234's Avatar
berry1234 berry1234 is offline
berry1234 is gaining momentum as a positive member of FTE.
Brown spark plug boots you are ok, black, you have the old head/plug design.
Old 05-07-2013, 10:05 AM
markinnaples markinnaples is offline
markinnaples is starting off with a positive reputation.
I have a 2008 Nav with the old style heads. I was gonna risk doing the spark plugs myself, but decided against it. The dealer charged me around $425 to change them, including a 10% off coupon the sent me. I changed the coil packs myself as they are extremely easy to change (went with the Accel aftermarket coil packs) and the truck is 100% better than it was. Next up is the transmission fluid change. May do that myself as well as I am fairly handy. I'd check around different dealers (Ford and Lincoln) and get the best price.
Old 05-07-2013, 12:16 PM
Quote:
Mark it's a easy job, I would say check around and find a 6R80 deep pan while you are at it that way you can get one that has a few extra quarts of capacity and also a quick drain plug. This makes changes much easier and you'll not mind doing them every 25K miles.
Old 05-07-2013, 12:18 PM
montecarlo21, great idea, thanks.
Old 04-06-2015, 03:15 PM
david_jr david_jr is offline
david_jr is starting off with a positive reputation.
I know this thread is a couple years old, but I didn't see anything more recent on a search. I just had a 60K mile service done on my 2008 Limited. I asked to have the spark plugs changed in addition to the other service because I am in a high rust area and don't think they'll get them out at 100K. The total bill came to $613.49. The breakdown is $45.39 for oil change, $164.19 for transmission service, $311.59 for spark plugs ($19.16 each for the plugs), $0 for multi-point inspection and $53.99 to replace 4 rusted lug nuts ($6.90 each plus $26.39 labor). BTW we have replaced all or most of the lug nuts on the truck over the last couple of years, 4 to 6 at a time due to rust. Also now getting a lot of rust just above the running board below the passenger front door, paint peeling off in sheets. Driver side seems fine. Dealer advises not covered under corrosion extended warranty.
2006 F-150 Engine Issues mattreck12 2004 - 2008 F150 5 07-20-2016 10:25 AM
66 F100 Rer Main Seal Sanonofregarage 1961 - 1966 F-100 & Larger F-Series Trucks 0 02-09-2016 08:49 PM
Heater Blend Door, Climate Control Module Issues F150Dood 2009 - 2014 F150 0 01-18-2016 06:19 PM
Any info on Cort Fox Ford in Hollywood? Captain Destructo General Automotive Discussion 3 01-13-2016 02:13 AM
NV Smog Reject for O2 Sensors BC23 2009 - 2014 F150 13 08-26-2015 04:40 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
