How much weight can my truck really pull? - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 04-29-2013, 07:37 PM
83FordPdx 83FordPdx is offline
83FordPdx is starting off with a positive reputation.
So I am looking at a new travel trailer. And I have heard conflicting information on how much my truck can actually pull.
Here is my truck info.
2004 F-250 Super Cab Super Duty. 5.4L 4x4
The trailer I am looking at has a dry of 5800lbs.
Thanks for the help.
Old 04-29-2013, 07:42 PM
senix's Avatar
senix senix is online now
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
Your towing guide:
You should be good for at least 7200 lbs.
Old 04-29-2013, 07:43 PM
powerstroke72's Avatar
powerstroke72 powerstroke72 is offline
powerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputation
Here's a link to the 2004 Towing Guide:
https://www.fleet.ford.com/showroom/...r_F250_350.pdf
A lot is dependent upon the axle ratio because there's a 1,500 difference between the 3.73 and 4.10.
Old 04-29-2013, 07:52 PM
I have the 3.73 ratio
So from reading the guide I am getting 7,100 lbs
Old 04-29-2013, 07:58 PM
senix's Avatar
It should pull it fine. Remember alot of the power is going to be made as the motor revs. It is ok to let it sing a bit.
Old 04-29-2013, 10:33 PM
Quad Racer's Avatar
Quad Racer Quad Racer is offline
Quad Racer is a name known to allQuad Racer is a name known to allQuad Racer is a name known to allQuad Racer is a name known to allQuad Racer is a name known to allQuad Racer is a name known to all
Like Scott said it'll pull it no problem.
You may consider a couple upgrades to your truck to prepare it for the task?
I consider how often I'd tow and the terrain.
Old 04-30-2013, 05:05 AM
drey04's Avatar
drey04 drey04 is offline
drey04 has a great reputation on FTE.drey04 has a great reputation on FTE.drey04 has a great reputation on FTE.drey04 has a great reputation on FTE.drey04 has a great reputation on FTE.
You'll be just fine. My dad's 30 footer weighs 7200 dry and 9300 loaded and I drag it around easily with my truck. Not gonna win any races, but she pulls strong.
Old 04-30-2013, 07:44 AM
jdadamsjr's Avatar
jdadamsjr jdadamsjr is online now
jdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputationjdadamsjr has a superb reputation
dry weight is a meaningless number - go by gvwr which will be a lost closer to what you will be towing... and then it's still a guide until YOU load it up and spend $10 at a cat scale to find out the real weights...
we can't know how many pairs of shoes your wife has to bring along for 'roughing it'
also, you didn't state if yours is an
auto or manual,
crew cab, supercab, or regular cab and
does it have the stock tires on it ????
and ASSUMING it's an auto and supercab and tow behind and not a 5th wheel...
To really get it right, all that makes a difference in what you can actually pull !
gcwr and rear axle weight rating are important numbers too..
good luck !
bottom line we're giving you ballpark answers until all the parameters are known...
if you say 7100 then it must be an automatic supercab f-250 4x4 3.73 5.4L ....
How much can I tow with this truck? 1965F100(3onthetree) 6.7L Power Stroke Diesel 13 10-29-2016 10:14 PM
2001 F150 Super Crew towing capacity COBRA028 1997 - 2003 F150 5 04-02-2014 02:28 PM
Hitch pin weight F250 SD 6.7 Jestercyco214 1999 to 2016 Super Duty 5 05-31-2012 11:18 AM
How Much Trailer Weight Patchez Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion 15 09-13-2011 01:35 AM
How much can I pull? adbradley 1973 - 1979 F-100 & Larger F-Series Trucks 6 04-16-2002 09:59 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
