1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
"Clunk" While Accelerating and Braking
Old 04-29-2013, 05:19 PM
mayorphill's Avatar
mayorphill
mayorphill is offline
So my '99 F350 4x4 is making a clunking sound and there is a distinct jolt in the truck while this is occurring.
Symptoms:
From a stop while accelerating, there is a distinct jolt and clunk. The best way I can describe the feeling is like something isn't tightened down all the way so there is a split second while inertia is generated and the "looseness" catches up to the acceleration.
When stopping, the clunk and jolt is generated when the truck comes to a complete stop. When the truck rebounds backwards a bit because of the suspension pulls it backwards after stopping, you will hear the clunk again.
I replaced the ball joints a week ago an a wheel hub bearing on the right side. I don't recall this before these repairs, but it may have been making this noise. I was more focused on the grinding from the wheel bearing so I may not have noticed the clunk and jolt then.
Any thoughts on where I should start looking for the problem?
Old 04-29-2013, 05:58 PM
acf6's Avatar
acf6
acf6 is offline
Drive shaft skip joint needs grease.
Old 04-29-2013, 06:37 PM
A/Ox4's Avatar
A/Ox4
A/Ox4 is offline
9 ECHO 1
X2 on the slip joint.
Old 04-29-2013, 08:23 PM
Pitcrw6's Avatar
Pitcrw6
Pitcrw6 is offline
Yep slip joint needs grease. Mine is doing that same thing but I just need to find the time to do it. I would post the link on how to do it but im on my phone. Maybe someone can post it for ya.
Old 04-29-2013, 10:39 PM
cogden's Avatar
cogden
cogden is offline
I have had bad U-Joints behave that way too. Once I had a U-Joint that only had one of the four bearings go out so you couldn't feel it by hand but the truck's torque caused it to move enough to make it clunk on acceleration and deceleration.
Good Luck!
Old 04-30-2013, 02:29 AM
RPM371's Avatar
RPM371
RPM371 is offline
Slip joint needs Teflon grease.
Old 04-30-2013, 11:14 AM
Rick03F250's Avatar
Rick03F250
Rick03F250 is offline
I hate to mention it could be the crush sleeve at the pinion gear also.
I hope it's just a grease issue. Mine wasn't !!
Old 04-30-2013, 11:32 AM
BigOl04's Avatar
BigOl04
BigOl04 is offline
mine has the same issue. i have been under there tightening everything and searching to find the answer.. guess i need to greese mine to.. can anyone post pics of how ans where and what type to use..
Old 04-30-2013, 01:45 PM
Jimmy Dean's Avatar
Jimmy Dean
Jimmy Dean is offline
If you're still having issues, I've had the same issue before. Started after doing work on the hubs.
Go back under the truck and retighten the caliper bolts. It seems I have to do this about 50 miles after I get the truck back on the road every time I pull the brakes.
That is why you are hearing it as the weight shifts back too, it is rotating the caliper just a hair around the hub, and it produces a thunk that you can hear and feel.
Try that, couldnt hurt to check it anyways, it takes about 2 minutes to do all 4 corners.
Old 04-30-2013, 04:33 PM
Tikki's Avatar
Tikki
Tikki is offline
Still having trouble? Check out the motor and transmission mounts, the rubbers might needing repolacement.
Old 05-01-2013, 11:17 AM
droldsmorland's Avatar
droldsmorland
droldsmorland is offline
Heres the thread:
https://www.ford-trucks.com/forums/11...=droldsmorland
Some other bits of useful info here too. Scroll down to the bottom of page 1. Then the grease PN is on page 2. Yes only use the FOMOCO grease! I learned this the hard way.
Old 05-01-2013, 12:51 PM
handifletch's Avatar
handifletch
handifletch is offline
link
I could not get on the page you listed Bad link?
Old 05-01-2013, 02:59 PM
zookdesign's Avatar
zookdesign
zookdesign is offline
I had an issue almost like this.. when stopping hard and keeping the brakes held, once I let off the diff would unbind and you could hear and feel a clang..greasing the splines on the drive shaft going into the transmission was the fix..
Old 05-03-2013, 10:55 AM
droldsmorland
try this link or do a search under my name or "mysterious-thump....Some other bits of useful info here too. Scroll down to the bottom of page 1. Then the grease PN is on page 2. Yes only use the FOMOCO grease! I learned this the hard way.
https://www.ford-trucks.com/forums/1...=droldsmorland
Old 05-03-2013, 12:00 PM
handifletch
Got it thanks, I am going to do this with ujoints this weekend
Quick Reply: "Clunk" While Accelerating and Braking
