"Clunk" While Accelerating and Braking - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 04-29-2013, 06:19 PM
mayorphill mayorphill is offline
mayorphill is starting off with a positive reputation.
So my '99 F350 4x4 is making a clunking sound and there is a distinct jolt in the truck while this is occurring.
Symptoms:
From a stop while accelerating, there is a distinct jolt and clunk. The best way I can describe the feeling is like something isn't tightened down all the way so there is a split second while inertia is generated and the "looseness" catches up to the acceleration.
When stopping, the clunk and jolt is generated when the truck comes to a complete stop. When the truck rebounds backwards a bit because of the suspension pulls it backwards after stopping, you will hear the clunk again.
I replaced the ball joints a week ago an a wheel hub bearing on the right side. I don't recall this before these repairs, but it may have been making this noise. I was more focused on the grinding from the wheel bearing so I may not have noticed the clunk and jolt then.
Any thoughts on where I should start looking for the problem?
Old 04-29-2013, 06:58 PM
acf6's Avatar
acf6 acf6 is offline
acf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputation
Drive shaft skip joint needs grease.
Old 04-29-2013, 07:37 PM
A/Ox4's Avatar
A/Ox4 A/Ox4 is offline
9 ECHO 1
A/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputation
X2 on the slip joint.
Old 04-29-2013, 09:23 PM
Pitcrw6's Avatar
Pitcrw6 Pitcrw6 is offline
Pitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant futurePitcrw6 has a brilliant future
Yep slip joint needs grease. Mine is doing that same thing but I just need to find the time to do it. I would post the link on how to do it but im on my phone. Maybe someone can post it for ya.
Old 04-29-2013, 11:39 PM
cogden's Avatar
cogden cogden is offline
cogden is starting off with a positive reputation.
I have had bad U-Joints behave that way too. Once I had a U-Joint that only had one of the four bearings go out so you couldn't feel it by hand but the truck's torque caused it to move enough to make it clunk on acceleration and deceleration.
Good Luck!
Old 04-30-2013, 03:29 AM
RPM371's Avatar
RPM371 RPM371 is offline
RPM371 is gaining momentum as a positive member of FTE.RPM371 is gaining momentum as a positive member of FTE.
Slip joint needs Teflon grease.
Old 04-30-2013, 12:14 PM
Rick03F250's Avatar
Rick03F250 Rick03F250 is offline
Rick03F250 is starting off with a positive reputation.
I hate to mention it could be the crush sleeve at the pinion gear also.
I hope it's just a grease issue. Mine wasn't !!
Old 04-30-2013, 12:32 PM
BigOl04's Avatar
BigOl04 BigOl04 is offline
BigOl04 is starting off with a positive reputation.
mine has the same issue. i have been under there tightening everything and searching to find the answer.. guess i need to greese mine to.. can anyone post pics of how ans where and what type to use..
Old 04-30-2013, 02:45 PM
Jimmy Dean's Avatar
Jimmy Dean Jimmy Dean is offline
Jimmy Dean has a very good reputation on FTE.Jimmy Dean has a very good reputation on FTE.Jimmy Dean has a very good reputation on FTE.Jimmy Dean has a very good reputation on FTE.
If you're still having issues, I've had the same issue before. Started after doing work on the hubs.
Go back under the truck and retighten the caliper bolts. It seems I have to do this about 50 miles after I get the truck back on the road every time I pull the brakes.
That is why you are hearing it as the weight shifts back too, it is rotating the caliper just a hair around the hub, and it produces a thunk that you can hear and feel.
Try that, couldnt hurt to check it anyways, it takes about 2 minutes to do all 4 corners.
Old 04-30-2013, 05:33 PM
Tikki Tikki is offline
Tikki is starting off with a positive reputation.
Still having trouble? Check out the motor and transmission mounts, the rubbers might needing repolacement.
Old 05-01-2013, 12:17 PM
droldsmorland's Avatar
droldsmorland droldsmorland is offline
droldsmorland has a good reputation on FTE.droldsmorland has a good reputation on FTE.
Heres the thread:
http://www.ford-trucks.com/forums/11...=droldsmorland
Some other bits of useful info here too. Scroll down to the bottom of page 1. Then the grease PN is on page 2. Yes only use the FOMOCO grease! I learned this the hard way.
Old 05-01-2013, 01:51 PM
handifletch handifletch is offline
handifletch is starting off with a positive reputation.
link
I could not get on the page you listed Bad link?
Old 05-01-2013, 03:59 PM
zookdesign zookdesign is offline
zookdesign is starting off with a positive reputation.
I had an issue almost like this.. when stopping hard and keeping the brakes held, once I let off the diff would unbind and you could hear and feel a clang..greasing the splines on the drive shaft going into the transmission was the fix..
Old 05-03-2013, 11:55 AM
Quote:
try this link or do a search under my name or "mysterious-thump....Some other bits of useful info here too. Scroll down to the bottom of page 1. Then the grease PN is on page 2. Yes only use the FOMOCO grease! I learned this the hard way.
http://www.ford-trucks.com/forums/12...=droldsmorland
Old 05-03-2013, 01:00 PM
Got it thanks, I am going to do this with ujoints this weekend
93 f150 4x4 automatic tranny issiues Timwolve 1987 - 1996 F150 & Larger F-Series Trucks 9 01-23-2014 12:05 PM
2004 F250 Jolt on takeoff, play in the steering. mapsford5 1999 to 2016 Super Duty 2 07-17-2013 10:42 AM
1992 Ford F150 straight 6 (jolt in reverse) Rynopwr Ford Inline Six, 200, 250, 4.9L / 300 12 02-24-2012 01:08 AM
?? for rear clunk experts Beanpod 1997 - 2003 F150 12 04-01-2007 11:43 PM
Clunking in 4 Wheel Drive Rando75 Clutch, Transmission, Differential, Axle & Transfer Case 6 08-20-2003 04:55 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
