Please decode this 60 4x4 COLOR MODEL TRANSMISSIONS AXLE - Ford Truck Enthusiasts Forums
Old 04-29-2013, 03:43 PM
old broke prospector old broke prospector is offline
old broke prospector is gaining momentum as a positive member of FTE.old broke prospector is gaining momentum as a positive member of FTE.
Found this near complete but very dirty and somewhat rusty old truck in the junk yard for $1000.
Thinking about getting it so I can get the 8 ft Flairside bed for a 62 4x4.
It currently has a 223 in it with a generator but I think it may have had a V8 originally as it has some AC add on stuff in the cab.
Tag is on the glove box door.
Last tagged 1983.
F10J0K61093
WB 118
COLOR L
MODEL 103
DATE 18H
TRANS FA
AXLE 02
GVW 5600
HP 126
RPM 4000
DSO 9229
Old 04-29-2013, 07:42 PM
theodore/teddy's Avatar
theodore/teddy theodore/teddy is offline
Refyred
theodore/teddy is a splendid one to beholdtheodore/teddy is a splendid one to beholdtheodore/teddy is a splendid one to beholdtheodore/teddy is a splendid one to beholdtheodore/teddy is a splendid one to beholdtheodore/teddy is a splendid one to beholdtheodore/teddy is a splendid one to beholdtheodore/teddy is a splendid one to behold
Last tagged 1983.
F10J0K61093 Fourth digit J = 223 6cyl sixth digit = Kansas
WB 118
COLOR L = dark green
MODEL 103 = f100 4x4
DATE 18H = 18 August
TRANS FA = Ford 3 speed (my 59 data plate says same and it came with 3spd)
AXLE 02 = Rear axle 3:89 front axle 3;92
GVW 5600
HP 126
RPM 4000
DSO 9229
Sounds like a great project!
If I have misstated any info, Bill AKA NumberDummy will be along and square me/us away.
Keep us posted on your progress and what your plans are for this truck (and of course pictures).
Old 04-29-2013, 08:15 PM
Damifiknow's Avatar
Damifiknow Damifiknow is offline
Damifiknow is starting off with a positive reputation.
Try this link.
1960 Ford Truck VIN
Old 04-30-2013, 03:26 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
F10J0K61093 / WB 118 / COLOR L / MODEL F103 / DATE 18H / TRANS FA / AXLE 02 / GVW 5600 / CERT NET HP 126 / RPM 4000 / DSO 9229
F10 = F100.
J = 223 1V I-6.
0 = 1960.
K = Kansas City MO Assembly Plant.
61093 = 1960 Numerical Sequence of Assembly, the trucks specific serial number.
118" Wheelbase.
L = Dark Green.
F103 = F100 4WD, 5,600 lbs. GVWR
18H = Assembled August (H) 18, 1960.
FA = Not listed in parts catalog. F = Warner T-98 / A = Ford 3 speed light duty manual trans.
02 = Ford 9" Rear Axle / 3.89-1 / No Limited Slip * / 3,300 lbs. Rear Axle Capacity / No 3rd digit of AXLE code listed which refers to front axle.
5,600 lbs. Gross Vehicle Weight Rating.
126 net HP @ 4,000 RPM
9229 = Domestic Special Order number. Truck was ordered special by original purchaser, not "bought off the lot."
* mercurytrucks.com (link in post 3) clueless: 1959 thru today: If the AXLE code begins w/a letter: Limited Slip / If with a number, no Limited Slip.
Vin/door tag decode? Rusty_Old_F250 1973 - 1979 F-100 & Larger F-Series Trucks 12 11-29-2013 03:09 PM
What other year/model has the same front axle? 1977fordhighboy 1973 - 1979 F-100 & Larger F-Series Trucks 4 07-06-2011 04:06 PM
VIN and Body Plate help? PLEASE srsully 1961 - 1966 F-100 & Larger F-Series Trucks 2 01-09-2011 09:59 PM
Need tags decoded- NumberDummy, thanks in advance. Bowtie_Schmowtie 1973 - 1979 F-100 & Larger F-Series Trucks 21 03-06-2009 06:59 PM
Rear Axle Tag question rockdawg84 1973 - 1979 F-100 & Larger F-Series Trucks 2 11-28-2007 11:39 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
