need help with transmission - Ford Truck Enthusiasts Forums
1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Old 04-29-2013, 03:39 PM
MR JDuece MR JDuece is offline
MR JDuece is starting off with a positive reputation.
i have an 01 5.4 expedition auto trans., as i am driving my truck seems like it slips into neutral, rpms go up but the truck slows down. if i down shift into lower gear im able to go again, then i'll go back into overdrive and it seems fine for a bit shifting through the gears, then a few moments later it seems like im back into neutral. can anyone please help me with diagnoses. will i need a new tranny or is it some internal parts i can change out..
Old 04-29-2013, 05:18 PM
alloro alloro is offline
alloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to behold
Not to state the obvious, but did you check the fluid level in Park with the tranny warmed up?
Old 04-29-2013, 09:06 PM
yes, the fluid levels were good and i even put lucas stop slip transmission in to see if that would help but it didn't...
Truck shifts into neutral grizzly6.0 6.7L Power Stroke Diesel 11 01-17-2012 04:15 PM
how the blazes do I shift? Stephen67 1948 - 1956 F1, F100 & Larger F-Series Trucks 15 07-21-2011 03:00 PM
'94 Auto Gear Selector Lever Suddenly Loose '94Mesquite Clutch, Transmission, Differential, Axle & Transfer Case 3 07-29-2009 03:56 PM
np203 grinding changing gears gsiamrod Clutch, Transmission, Differential, Axle & Transfer Case 0 07-08-2009 05:35 PM
tranny problems big truck driver 1987 - 1996 F150 & Larger F-Series Trucks 1 09-15-2003 06:27 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
