Duraspark control module
Which 'stock one' might that be? 1974/79: There are FIVE different DuraSpark ignition modules. The wiring/plugs are all different, so none interchange.
Modules identified by a colored plastic square above where the wires feed out.
What color is yours? What color is the OP's?
Yikes -- had no idea there were so many of these. I'm going to take a photo of it tonight and see if it will work for him.
All that's needed to be known is the color of the plastic square, as otherwise...the modules look the same. Plastic square could be black - blue - brown = green - red - yellow
Yellow replaced brown / red only used on some 1976/79 CA vehicles.
1976/79: Most common is blue module that was also used well into the 1990's.
1U2Z-12A199-AA (replaced D6AZ-12A199-A; D8VZ-12A199-A & D9VZ-12A199-A) .. Ignition Module-Blue (Motorcraft DY-893) / Available from Ford.
MSRP: $120.84.
FTE Ford Dealer Parts Dept sponsor tousleyfordparts.com price: $73.11 / Tousley Ford - White Bear Lake MN
FTE Ford Dealer Parts Dept sponsor silverstatefordparts.com price: $78.47 / Gaudin Ford - Las Vegas NV
FTE Ford Dealer Parts Dept sponsor horizonpartsguy.com price: $79.75 / Horizon Ford - Seattle (Tukwila) WA
MSRP: $120.84.
CentralMassLandscape
15
02-08-2019 12:07 AM
oliver28472
07-29-2012 12:43 PM
1972 Ford Thunderbird 429 V8
11-16-2002 11:26 AM
