98 F150 brake controller
All,
I'm in the process of putting a brake controller and 7 pin plug in on my 98 F150 Super Cab, 4x4, 4.6 L with a auto trans. Got the Tekonsha Voyager hooked up to the existing harness under the dash. I have the 7 pin installed out back and thats where my problem begins. The 7 pin harness came with 3 30amp fuses and 2 relays that need to be placed in the power distribution box under the hood. I can figure out where the fuses go but my manual says nothing about the relays. The relays that are already in the box are for things like fuel pump etc. Any help on placing these relays is greatly apprectiated.
I just did the excact same thing on my 02.
Process of alimination is what i used.. using the manual.. The 7 way connector kit had fuses and relays and i didn't use them all. Just two relays, I don't remember if i uses a fuse.. I will run out and take a picture and you can see if you can match it up.
If you have a 98 owner manuel, pages 134-138 have the power info.
In the engine bay box, fuses 1, 16, 28 are involved.
Under the dash fuses 18, 23 are involved and there may be some others on a quick look at the info..
Your 98 is not layed out an well as later years, for trailer tow.
If the trailer has electric brakes, a break-away battery has to be powered and under charge along with all the other functions through the 7 pin plugup..
For a copy of your manuel, look up Ford Fleet Maintanece website and down load your year.
Good luck.
Good luck.
EDIT:Hope nobody read that yet, been a while since i looked at it since i have the tow package but nothing to tow right now. Found this pic.
http://www.f150online.com/forums/mem...ojectsho89.jpg
thats the same way my '98 250 ld is setup.
66fdtrucknut
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
06-04-2010 06:59 PM
02 limited 4x4
07-21-2005 02:30 AM
