Coil issue- 04 Ford F150 XLT 5.4 Triton - Ford Truck Enthusiasts Forums
Old 04-28-2013, 10:16 PM
handell35 handell35 is offline
handell35 is starting off with a positive reputation.
Having problems with coil F (6) throwing a check engine light. Been repaired by Ford with a new coil. 2 weeks later threw another code same coil F (6). Went back they said plugs were loose and needed tightened, so they re tightened and sent me on my way. 1 month later threw another check engine light same coil F (6).
Any ideas?
For the time being I switched coil 6 with coil 5 to see if I got a code from 5. Then I could rule it as a bad coil. Drove over 200 miles without an issue as of right now.
Truck details
2004 Ford-F150 XLT 5.4 Triton- 107,xxx
Old 04-29-2013, 01:44 PM
tooldad tooldad is offline
tooldad is starting off with a positive reputation.
Could be a bad connection in the COP wiring harness plug. Also, be aware, I replaced all 8 of mine with Motorcraft COP's one year ago and have just replaced the fifth bad one out of the batch. The bad thing is that I just replaced them last year as a preventative maintenance measure. So it could be a problem with the replacement COP too.
Did somebody say, don't fix it if it ain't broke?
Old 04-29-2013, 03:37 PM
Thanks for your help man. All I can do is wait now.
2000 5.4 Triton missing out... after tune up Mr_CarMan007 1997 - 2003 F150 9 09-22-2015 06:41 AM
Technical help needed Rider48 Modular V8 (4.6L, 5.4L) 2 06-19-2015 10:26 PM
2000 5.4L coil-on-plug problem--Help? SQUIRMIN VERMIN 1997 - 2003 F150 5 06-24-2014 06:40 PM
2000 f150 5.4 throwing code p0358 ghostsd 1997 - 2003 F150 2 06-20-2014 10:16 PM
5.4 misfire/backfire/running rough. Barret88 1999 to 2016 Super Duty 1 01-26-2014 04:04 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
