ford f250 5.4 gauges - Ford Truck Enthusiasts Forums
Old 04-28-2013, 11:20 AM
Bigdoon1522 Bigdoon1522 is offline
Bigdoon1522 is starting off with a positive reputation.
i got my 03 f250 5.4 that im installing gauges on and i can get the amp gauge to work and cant figure out how to wire the oil psi censer any advice
Old 04-30-2013, 07:33 AM
JWA's Avatar
JWA JWA is offline
JWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputation
What advice do you need or want?
Are these aftermarket gauges--what brand? Did the oil pressure gauge come with or have recommended a sensor? The typical OP stock sensor is nothing more than an on/off switch, doesn't read pressure per se.
When the proper sensor is in place wiring is simple from there, just follow manufacturers instructions.
BTW those are typically the first thing I disregard----don't need no stinkin' directions!
Old 04-30-2013, 10:05 AM
They are all sunpro gauges and Where its the factory psi senser on the truck i cant find it and i cant get the amp meter to get a reading if the alternator
Old 05-02-2013, 06:01 AM
nogo73's Avatar
nogo73 nogo73 is offline
nogo73 is starting off with a positive reputation.
I recommend that you need to find a 12-volt ignition source and use the jumper wire to the Light Green/Red(not sure) wire. What that will do is it will energize the alternator when the ignition is turned on.
*******Alternator will not charge if you do not do this********.
by the way I am running autometer in mine. I could not get my alternator to charge at all before doing this I looked it up in the chiltons and florida 5.0 website.
Old 05-02-2013, 07:29 AM
JWA's Avatar
JWA JWA is offline
The oil pressure sending unit on your motor should be just forward of the oil filter, along the "rail" bolted to the block. It will be a single wire connection.
I can snap a photo if you need? Would take an hour or so from this post.
Lemme know!
J W
Old 05-02-2013, 01:48 PM
If u could that would be great and do any of u know how to wire a air fuel ratio gauge and an amp gauge
Old 05-03-2013, 08:46 AM
JWA's Avatar
JWA JWA is offline
You might want to contact your gauge manufacturer for install information.
Here's a photo of the oil sending unit's location---I have a Tee installed but its in the same place:
HTH
Old 05-04-2013, 10:53 PM
LxMan1's Avatar
LxMan1 LxMan1 is offline
LxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant futureLxMan1 has a brilliant future
Most aftermarket amp gauges require you to run all of the current thru the gauge.
I always used a heavy gauge wire to and from the gauge. Remove all of the wiring (except for the main battery cable) from the battery side of the starter solenoid and connect them to one side of the gauge. Then hook the other side of the gauge to the starter solenoid terminal along with the battery cable. once hooked up, turn on the headlights and make sure that the gauge goes to the - side of the gauge. If not, reverse the wires on the back of the gauge.
That being said, that was on a 71 Torino that only had a 65amp alternator. Not a lot of amperage compared to modern vehicles. What amp does the gauge go to? If only +/- 60, then I wouldn't use it.
They may offer something a bit safer to wire up, I would email them to see.That's why when I put a set of gauges in my 88 Mustang, I opted for the set with a Volt gauge instead of an Amp gauge. Just wired it to a "key on" blank spot in the fuse panel.
Old 05-05-2013, 08:07 AM
JWA's Avatar
JWA JWA is offline
I also wanted a direct reading amp gauge, one that would exceed the 60 amp most common for autos/trucks. AutoMeter told it was their opinion (lawyers really) that said direct reading gauges in the 100+ amp range were unsafe since the high heat of enclosed mounting areas would cause problems.
While there are low amp draw gauge types that measure current far far exceeding what the standard automotive alternators produce they don't easily fit or mount into automotive installations. While the voltage gauges are basically "good enough" I'd still like to know what current is being produced but also know in this day and time anything of 60 amps just isn't available.
Temp gauge Xcursion88 1997 - 2003 F150 3 10-12-2015 11:51 PM
Need help! eratic temp gauge z31freakify 1999 to 2016 Super Duty 3 09-15-2015 08:08 PM
5.4 Temp gauge issue? Hotairjunkie Modular V8 (4.6L, 5.4L) 2 07-31-2015 09:56 PM
Gas Gauge Problem xd2200 1999 to 2016 Super Duty 0 06-13-2014 02:41 PM
Ford F250 5.4 Boost/Vacuum Gauge Bigdoon1522 1999 to 2016 Super Duty 1 03-20-2014 12:08 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
