Starter Selenoid relay
Old 04-26-2013, 06:13 PM
Buck268's Avatar
Buck268
Buck268 is offline
Does anybody have the testing proceedure for tbhe starter selenoid realy in a '99 5.4L? I suspect mine is going on the fritz but cannot confirm it as chiltons does not offer a dx proceedure.
Old 05-04-2013, 09:57 PM
LxMan1's Avatar
LxMan1
LxMan1 is offline
Just use a test light or meter. With the key in the start position, you should have voltage to the small trigger wire, as well as battery voltage to both of the large posts. If no voltage to the small wire, then your problem is before the solenoid. If you have voltage to all 3 with the key turned, then you have either a bad connection on the starter or ground.
There is also a solenoid on the starter itself. so it could be either one.
Old 05-05-2013, 07:13 AM
projectSHO89's Avatar
projectSHO89
projectSHO89 is online now
Starter relay is on the firewall, the starter solenoid (often called the Bendix) is mounted on the starter motor. Two different parts.
dbail3
Electrical Systems/Wiring
09-18-2014 07:07 PM
mediaman67
15
01-06-2014 09:23 PM
leforrest
1997 - 2003 F150
01-24-2013 07:34 PM
ralbach
07-18-2009 08:24 AM
buttnuttn8
10-22-2002 07:19 AM
Quick Reply: Starter Selenoid relay
