Help ford 1985 Econoline - Ford Truck Enthusiasts Forums
Old 04-28-2013, 03:33 AM
fordf350camper's Avatar
fordf350camper fordf350camper is offline
fordf350camper is starting off with a positive reputation.
Hi all i am noot to sure were to ask this question so i thought i would try here.I have just brought a 1985 ford econoline dy van Lhd with me living in the uk i would like rhd so the question is if i cannot find a rhd steering box will another van one fit.So i could look over here in the uk.Also its a 5 litre so what engine is it.Is it a 302.Does the van have its own chassis frame.Do you have a picture would it be the same as a E350 thanks
Old 04-28-2013, 02:47 PM
bc4x4f250's Avatar
bc4x4f250 bc4x4f250 is offline
bc4x4f250 is starting off with a positive reputation.
Camper,
You will find the following section better suited for your Van;
1968 - Present Full Size Vans
Econolines are vastly different... the model years of 1967/earlier basically have nothing in common with those manufactured from model year 1968/later.
However, we'll try and help...
ENGINE:
Ford 302 = Ford 5.0, as does a 351 = 5.8... the math might not be exact, but that is how it plays out. As an aside, it is not uncommon to find Econolines in the U.S. with 460's in them... yeah, that's 7.5 Liters of fun.
BODY/ CHASSIS:
Ford Econolines are constructed of a separate Body and Chassis, meaning, yes it has a frame onto which the sheet metal attaches. They are NOT uni-body construction.
RIGHT-HAND DRIVE (RHD) OPTION:
I know of no U.S. Ford Econoline vans (note; these were basically built in only one facility) that were shipped to markets requiring such. A RHD conversion would be doable, since the front-end suspension is rather simple and rudimentary. But, finding the bits & pieces, along with the expertise is the biggest problem I can see. I suspect those Ford guys, who are experts with the [U.K.] Ford Transit's and Cargo's would be you best source.
** I suspect the major issue might be foot clearance... even after swapping out the dashboard/ heater, you must note that the Econoline has an engine that does not sit centered in the frame. In fact, the engine is biased towards the right-side of the van (likely done, since Ford engineers decided the right-hand side would be for passengers - and never intended/considered it to sell this in markets requiring drivers on that same side). **
You might also consider contacting some of the hotrodder's on your side of the pond... if there are guys into U.S. cars, and they are modifying them, I will bet a fair share have already done RHD modifications.
In the end, it comes down to engineering and dollars (or, Euro's)... it can be done, how much have you got?
Good luck...
p.s. (Knebworth Park/ 1979... Led Zeppelin was amazing)
p.p.s. ('Top Gear' is the best program on television, period!)
Trivia; 2013 is the end of the road for the Ford Econoline as we have known it... model year 2014 will bring about a very European inspired/ designed/ named Transit!
1971 Ford RHD Postal Van John Durant 1967 - 1972 F-100 & Larger F-Series Trucks 35 10-25-2016 05:48 PM
1997 f150 LHD to RHD anyone done the swap fordf350camper 1997 - 2003 F150 1 11-06-2015 07:25 PM
Right hand drive F1 truck? David Hall 1948 - 1956 F1, F100 & Larger F-Series Trucks 23 06-04-2013 06:34 AM
Ford f350 1957 LHD to RHD possible or not fordf350camper 1957 - 1960 F100 & Larger F-Series Trucks 9 08-27-2012 02:13 PM
RHD Conversion sanmarco Western Region 0 09-21-2011 01:58 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
