Truck Wont Start BUt Battery good - Ford Truck Enthusiasts Forums
General Automotive Discussion
Old 04-27-2013, 11:09 PM
lditges1 lditges1 is offline
lditges1 is starting off with a positive reputation.
I have a 2000 Ford F250 7.3 when I slam the hood it will power up but as soon as I plug the key in the truck immediately dies. I tested the battery is good. Please Help stuck in midland if I cant figure this problem out.
Old 04-27-2013, 11:49 PM
Furyus1's Avatar
Furyus1 Furyus1 is offline
Furyus1 has a superb reputationFuryus1 has a superb reputationFuryus1 has a superb reputationFuryus1 has a superb reputationFuryus1 has a superb reputationFuryus1 has a superb reputationFuryus1 has a superb reputationFuryus1 has a superb reputationFuryus1 has a superb reputationFuryus1 has a superb reputationFuryus1 has a superb reputation
Welcome to FTE.
How did you test the battery - was it tested under load?
Old 04-28-2013, 01:18 AM
ford2go's Avatar
ford2go ford2go is offline
ford2go has much to be proud offord2go has much to be proud offord2go has much to be proud offord2go has much to be proud offord2go has much to be proud offord2go has much to be proud offord2go has much to be proud offord2go has much to be proud offord2go has much to be proud offord2go has much to be proud of
Please give a few more details --
Sounds like you 'somehow' get it started when you slam the hood -- are you using your remote?
Then when you put the actual key in it dies. Do I have that right?
If it's a key that works with the anti theft, maybe it's not being recognized. I know almost nothing about those systems, but I would assume that a dealer could check to see if the chip in the key is working.
Good Luck,
hj
Old 04-28-2013, 12:55 PM
galaxie641 galaxie641 is offline
galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.
Pull the connections off, clean and reinstall, also make sure the cables aren't rotting out under the insulation.
Learned something new about battery testers. Realslowww Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 20 01-03-2016 09:31 AM
Battery Light Wont Go Away bruno2 1987 - 1996 F150 & Larger F-Series Trucks 7 04-27-2015 09:28 PM
battery cable rungunner 1994.5 - 1997 7.3L Power Stroke Diesel 2 07-12-2014 03:02 PM
Battery drain Insane451 Expedition & Navigator 8 04-03-2014 12:05 PM
98 Navi negative battery cable replacement dangitsbrandon Electrical Systems/Wiring 2 07-15-2013 08:54 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
