Auxiliary Relay Box - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Auxiliary Relay Box
Old 04-27-2013, 05:16 PM
RangerWilly RangerWilly is offline
RangerWilly is starting off with a positive reputation.
Auxiliary Relay Box
Could someone direct me to the location of my Auxiliary Relay box on my 2001 Ford Ranger 4wd Ext.Cab?I have the factory shop manuals but they do not show its location.The fuse box is easy to fine,so is the battery junction box.But where is the Auxiliary Relay box? I need to check the
C1022 Interior Lighting relay.Thanks.
Old 04-27-2013, 08:55 PM
Rockledge's Avatar
Rockledge Rockledge is offline
Rockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to behold
That relay box is located inside the cab, underneath the steering column. It has maybe 5-6 relays inside of it...
Old 04-28-2013, 10:59 AM
One more question Rockledge. Is its location behind the dash under the steering column or under the steering column just the other side of the
steering wheel? Thanks.Rangerwilly
Old 04-28-2013, 04:23 PM
Rockledge's Avatar
It's mounted underneath the dash just to the right of the steering column, in the area above the gas pedal. It's the only relay box in that area that's large enough to house 5-6 relays. You can confirm it's the right box by taking note of the colors of the wires leading in and out.
Old 05-02-2013, 07:22 PM
Thank you Rockledge!!!
Help needed - Turn signals Big Big Blue 1973 - 1979 F-100 & Larger F-Series Trucks 5 01-15-2015 08:56 PM
Relay fun! Charles2703 1973 - 1979 F-100 & Larger F-Series Trucks 13 06-16-2014 04:24 PM
ESOF 4WD RELAYS w/pics TIUSER Excursion - King of SUVs 11 03-16-2014 12:57 PM
Location of Auxiliary box #1? Airzima Explorer, Sport Trac, Mountaineer & Aviator 1 09-23-2012 12:56 PM
Auxiliary A/C Relay? tgspencer Expedition & Navigator 2 10-16-2008 08:54 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
