Carb and Dist - Ford Truck Enthusiasts Forums
Carb and Dist
Old 04-27-2013, 03:42 PM
cjohn2000 cjohn2000 is offline
cjohn2000 is starting off with a positive reputation.
Carb and Dist
Heres a little background I have a rusted out 1978 Ford Courier XLT w/ 2.3 and 4spd. Grandpa bought it new in '78, dad bought it in '88 and I got it free in 2011. In that time it got a new head after it wore off one of the lobes on #4 cylinder and a new float. I rebuilt (or attempted to) the original Hitachi carb, and put it back on the truck. The issues I was having with it when I put it back on is I couldn't adjust rich lean let alone get it to idle smoothly. I just ordered a weber 32/36 kit for it. Now my question is, do I need to abandon the factory distributor and black box since I am switching carbs? The reason I ask is there were different solenoids on the carburator seemingly controlled by the black box. Thanks, Corey
Old 05-13-2013, 12:08 AM
Stinky1 Stinky1 is offline
Stinky1 is starting off with a positive reputation.
I have no idea. But, back when I was a young-un all of my friends had mini-trucks. I had a '76 LUV and my buddy Tom had a Courier. Tom's had a 1600, or 1800 in it.
I replaced the original carb w/a Holly-Weber (close to what you have) that were found on the Pintos. It is a welcome change.
Chris had a 2000cc Datsun. He followed my lead and it warmed up his motor. I also put one of those carbs on a 20r.
Stand-by to be well-pleased with your carb.
Does it have a points dizzy? If so, get rid of it. My guess is that the black box does NOT control the timing as that would be a bit complex for that era. I don't know what kind of dizzy that you could replace it with.
Pop the top on the distributor (dizzy)...does it have centrifugal advance (arms, that fly outwards, in side it and turn/advance the rotor shaft). Does it have vacuum advance? A canister on the side of the dizzy, w/a hose that gets vacuum from the carb...put a clean hose on the canister and suck on it...does it rotate the rotor shaft.
If you have both of those, then you probably have a good dizzy that will stand alone.
A 2300...is the same motor that the Pinto used. It is a good motor design....except that it has a cast-iron head and block and it is heavy. But, it is durable. If it is the same, there are a lot of performance parts for it out there and you can find a good performance dizzy for it, or at the very least a stock electronic ignition dizzy.
Take a look at Wikipedia. It will probably have a bunch of those answers.
http://en.wikipedia.org/wiki/Ford_CourierFord Pinto engine - Wikipedia, the free encyclopedia
These guys will have a dizzy...if you decide to change.
Welcome to Esslinger Engineering
Reviving dad's 74 F100 (one owner truck) Rogue_Wulff 1973 - 1979 F-100 & Larger F-Series Trucks 111 09-01-2014 08:44 PM
Nitrophyl floats johnf3504x4 1973 - 1979 F-100 & Larger F-Series Trucks 2 12-07-2013 09:56 AM
New TPS sensor now 0 volts pmbennett11 Electrical Systems/Wiring 2 10-16-2013 06:44 PM
Holley Carb Identification Raptor119 1973 - 1979 F-100 & Larger F-Series Trucks 3 04-08-2012 12:25 PM
750CFM vs 600CFM Clifford II 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 19 05-08-2004 03:41 PM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
